Hello,
I am new in this forum, but not for arduino. I have been using arduino boards with no problem.
I have a strange problem with uploading a sketch. After compilation Arduino IDE shows that uploading is done ![]()
But Arduino Nano v3 does not show any sign, Rx,Tx does't blink. From other PC i can upload, so arduino nano v3 board is working fine. I also can capture messages from serial port, so serial communication is working. Tried reset board manualy- not working.
All this started after MegunoLink Pro Free Trial was installed.
After installation i installed arduino ide monitor, that it should stop com port and let arduino ide upload the sketch. After that i tried this function but it didnt worked, Arduino IDE showed a problem that COM port is in use. Next step was turn off manualy monitoring in MedunoLink and tried to upload sketch, then i noticed that it does not upload it.
What should i do?
So if someone will face this kind of problem i found a solution ![]()
I tryed to uninstal MedunoLink Pro and Arduino, then installed arduino IDE and its working again.
Cheers,
Martynas
Sorry about this. We've noticed some people are having trouble uploading after installing MegunoLink Pro's Arduino Integration features. The problem is related to our upload monitor tool which automatically releases the serial port when you upload. We are working on a fix.
In the mean time, a work around is to remove the upload monitor. Choose "Setup Arduino Integration" from the gear menu, choose "Remove" in the bottom panel (Arduino Upload Monitor) and click "Update Installation"
If you could let us know (http://http://www.megunolink.com/contact/report-a-bug/) what version of Windows & Arduino you are using, it would be a big help.
Paul.
I've just published an updated version which should fix the problem with the Arduino IDE not being able to upload after the MegunoLink Pro upload monitor has been installed.
To get the fix:
- Download the update from Download Free Trial | MegunoLink (if MegunoLink Pro doesn't update automatically)
- After installing the update, select Setup Arduino Integration from the gear menu
- Check that the install/update option is selected for the Arduino upload monitor and click the update button.
MegunoLink Pro will now automatically disconnect when the Arduino IDE tries to upload files and uploads from the Arduino IDE should work correctly.
If you have any further trouble, please get in touch: Contact Us | MegunoLink
Have a great day,
Paul.
