I'm trying to program a Nano using a Leonardo as an ISP.
I've got as far as getting avrdude to read the device signature and fuse settings correctly:
Reading | ################################################## | 100% 0.00s
avrdude.exe: Device signature = 0x1e950f (probably m328p)
avrdude.exe: safemode: Fuses OK (E:FD, H:DA, L:FF)
but every time I try to program a sketch I end up with this:
avrdude: verification error, first mismatch at byte 0x0002
0x40 != 0x5c
So it seems that nothing is actually being programmed at all. I've got the devices connected via their ICSP headers and the latest version of the ArduinoISP sketch loaded on the Leonardo.
Ideas welcome!
Here's the full output when trying to upload a sketch:
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM4
Using Programmer : arduino
Overriding Baud Rate : 57600
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\ian\AppData\Local\Temp\arduino_build_396254/Blink.ino.hex"
avrdude: writing flash (924 bytes):
Writing | ################################################## | 100% 0.54s
avrdude: 924 bytes of flash written
avrdude: verifying flash memory against C:\Users\ian\AppData\Local\Temp\arduino_build_396254/Blink.ino.hex:
avrdude: load data flash data from input file C:\Users\ian\AppData\Local\Temp\arduino_build_396254/Blink.ino.hex:
avrdude: input file C:\Users\ian\AppData\Local\Temp\arduino_build_396254/Blink.ino.hex contains 924 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.30s
avrdude: verifying ...
0x40 != 0x5c
avrdude: verification error; content mismatch
avrdude done. Thank you.
the selected serial port
does not exist or your board is not connected
