Nano vs. Uno
Does the Nano (from Gravitech) come with the bootloader already installed? I have a serial comm application currently running on an Uno; I’d like to replace the hardware with a Nano. Will Uno code run on a Nano? And finally, will the default Arduino IDE work with a Nano?
Thanks!
Look in the boards menu in the IDE.
I would hope so.
Yes, it uses the same processor. You'll get problems if you used a different firmware for the ATmega16U2 of the UNO (the USB2serial on-board adapter).
Yes.
