nano won't display LCDs.
Tried moving working Uno sketches to Nano and can’t get lcd displays to work with Nano
IDE: 1.8.13
Processor: AtMega 328 (Old Bootlegger)
Programmer: AVRISP Markl
Port: Both CH340 & Com
NANO: HILetgo Using Atmel Atmega328P-AU MCU
LCD and LCDI2C displays don’t work even though sketches work if sensors directed to serial port. Displays worked on UNO.
For Nano I tried changing lcd variable to 03f etc. With 4 wires w/l2C not much confusion but rearranged various options.
The AVRISP occurred because I was playing option roulette trying to get Nano to work. The ‘old bootleggar’ for the same reason.
#include <DallasTemperature.h>
#include <OneWire.h>
float myTemp;
float myHiTemp;
float myLowTemp;
#define One_Wire_Bus 4
OneWire oneWire(One_Wire_Bus);
DallasTemperature sensors(&oneWire);
LiquidCrystal_I2C lcd(0x27, 16, 2);
  sensors.begin();
  lcd.begin();
  sensors.requestTemperatures();
  float currentTemp0;
  currentTemp0 = sensors.getTempCByIndex(0);
  float currentTemp1;
  currentTemp1 = sensors.getTempCByIndex(1);
  Serial.print("Temp0 = ");
  Serial.print("\t");
  Serial.print(currentTemp0, 2);
  lcd.setCursor(0,0);
  lcd.print("Low Temp = ");
  lcd.print(myLowTemp);
  Serial.print("\Temp1 = ");
  Serial.print("\t");
  Serial.println(currentTemp1, 2);
  Serial.print("\Temp2 = ");
  Serial.print("\t");
  delay (1000);
Schematic?
Code?
Photos?
Uno and Nano use the same processor so the code should be the same. My guess is that there is a wiring problem. So, yeah, what Perry said.
I will give you a medal if you have the original RS232 AVRISP Programmer.
This topic was automatically closed after 120 days. New replies are no longer allowed.
