nano wont upload
hi every my arduino nano wont upload the code i want i sit for like 5 minutes and then get this
Arduino: 1.8.5 (Windows 10), Board: “Arduino Nano, ATmega328P”
Sketch uses 14362 bytes (46%) of program storage space. Maximum is 30720 bytes.
Global variables use 1547 bytes (75%) of dynamic memory, leaving 501 bytes for local variables. Maximum is 2048 bytes.
Low memory available, stability problems may occur.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x6a
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x6a
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x6a
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x6a
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x6a
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x6a
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x6a
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x6a
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x6a
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x6a
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
“Show verbose output during compilation”
option enabled in File → Preferences.
i have no idea what to do and what is wrong
here’s the code
#include <Wire.h>                  // This library allows you to communicate with I2C
#include <Adafruit_GFX.h>          // Adafruit GFX graphics core library
#include <Adafruit_SSD1306.h>      // Driver library for 'monochrome' 128x64 and 128x32 OLEDs
// Define the PINS you're goint to use on your Arduino Nano
int controller1 = 2;               // ANALOG 2
int controller2 = 3;               // ANALOG 3
int ledPin = 4;                    // DIGITAL 4
int btnPin = 5;                    // DIGITAL 5
// Define variables
int buttonState = 0;               // HIGH = Pressed
int gameState = 0;                 // 0 = Home, 1 = Game, 2 = End
int controllerValue1 = 0;          // variable to store the value coming from the potentiometer
int controllerValue2 = 0;          // variable to store the value coming from the potentiometer
int paddlePositionPlayer1 = 0;
int paddlePositionPlayer2 = 0;
int scorePlayer1 = 0;
int scorePlayer2 = 0;
int ballX = 128/2;
int ballY = 64/2;
int ballSpeedX = 2;
int ballSpeedY = 1;
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
#if (SSD1306_LCDHEIGHT != 64)
  #error("Height incorrect, please fix Adafruit_SSD1306.h!")
#endif
  pinMode(ledPin, OUTPUT);
  pinMode(btnPin, INPUT);
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);  // initialize with the I2C addr 0x3C (for the 128x64)
  display.clearDisplay();
  digitalWrite(ledPin, HIGH);                 // Status led on...
  // Read controller value and calculate paddle position
  controllerValue1 = analogRead(controller1);
  controllerValue2 = analogRead(controller2);
  paddlePositionPlayer1 = controllerValue1 * (46.0 / 1023.0);
  paddlePositionPlayer2 = controllerValue2 * (46.0 / 1023.0);
  // Set button state
  buttonState = digitalRead(btnPin);
  if (buttonState == HIGH && gameState == 0) {
      gameState = 1;
      delay(100);
  } else if (buttonState == HIGH && (gameState == 1 || gameState == 2)) {
      gameState = 0;
      scorePlayer1 = 0;
      scorePlayer2 = 0;
      ballX = 128/2;
      ballY = 64/2;
      delay(100);
  if (gameState == 0) {
    display.setTextSize(2);
    display.setTextColor(WHITE);
    display.setCursor(40, 18);
    display.println("PONG");
    display.setTextSize(1);
    display.setCursor(32, 38);
    display.println("press start");
    display.display();
  if (gameState == 1) {
    drawField(scorePlayer1, scorePlayer2);
    collisionControl();
    drawBall();
    display.display();
  if (gameState == 2) {
    if (scorePlayer1 == 2) {
      display.setCursor(15, 30);
    } else if (scorePlayer2 == 2) {
      display.setCursor(77, 30);
    display.println("winner!");
    display.display();
void drawField(int score1, int score2) {
    display.fillRect(0, round(paddlePositionPlayer1), 2, 18, 1);
    display.fillRect(126, round(paddlePositionPlayer2), 2, 18, 1);
    display.setCursor(55, 0);
    display.print(score1);
    display.print(":");
    display.print(score2);
    display.fillRect(63, 12, 1, 5, 1);
    display.fillRect(63, 22, 1, 5, 1);
    display.fillRect(63, 32, 1, 5, 1);
    display.fillRect(63, 42, 1, 5, 1);
    display.fillRect(63, 52, 1, 5, 1);
    display.fillRect(63, 62, 1, 5, 1);
void collisionControl() {
  //bounce from top and bottom
  if (ballY >= 64 - 2 || ballY <= 0) {
    ballSpeedY *= -1;
  //score points if ball hits wall behind player
  if (ballX >= 128 - 2 || ballX <= 0) {
    if (ballSpeedX > 0) {
      scorePlayer1++;
      ballX = 128 / 4;
    if (ballSpeedX < 0) {
      scorePlayer2++;
      ballX = 128 / 4 * 3;
    if (scorePlayer1 == 2 || scorePlayer2 == 2) {
      gameState = 2;
  //bounce from player1
  if (ballX >= 0 && ballX <= 2 && ballSpeedX < 0) {
    if (ballY > round(paddlePositionPlayer1) - 2 && ballY < round(paddlePositionPlayer1) + 18) {
      ballSpeedX *= -1;
  //bounce from player2
  if (ballX >= 128-2-2 && ballX <= 128-2 && ballSpeedX > 0) {
    if (ballY > round(paddlePositionPlayer2) - 2 && ballY < round(paddlePositionPlayer2) + 18) {
      ballSpeedX *= -1;
void drawBall() {
  display.fillRect(ballX, ballY, 2, 2, 1);
  ballX += ballSpeedX;
  ballY += ballSpeedY;
Had the same issue with my new nano. the following should work if you have a new nano(after jan 2018). Fixed by upgrading arduino software via board manager. I also installed the driver by googling arduino nano driver ch341ser.exe and installing it. Not sure which fixed it but try the arduino update first. once done, in tools, make sure board is arduino nano, processor at atmega328p and programmer is arduino as isp. Good luck.
Steve14:
Both fixes are needed if your Nano has the CH340 chip and if your Nano has the new bootloader.
