I'm trying to make a Nano 33 IoT - ATSAMD21 - board work on Windows 10. The board is connected and the LEDs are blinking properly. However, it looks like Windows cannot assign a proper COM port for communicating with the board. What I've tried to far with my Nano 33 IoT: - Installed "Arduino SAMD Boards" from the Boards Manager;
moderator edit: spam removed
@adomanim
The Nano33 IoT uses a microUSB port (if I'm not mistaken). MicroUSB cables come in two flavours: charge-only and sync.
With a charge-only cable, there will be no data transfer and hence the PC will not recognise your board. If your cell phone has a microUSB port, try the cable that came with it for data transfer.
You should have started your own topic.
Your topic was moved to its current location as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Thank you
It's been a long time since I worked with com ports but, if I remember correctly, a PC uses true RS-232 com protocol so the data will be inverted and will swing between -12V and +12V.
@herbschwarz , quite sure that that doesn't apply here when using USB.
Yes, using USB avoids the over voltage situation. I jumped to confusion, I'm sorry.
