What you're describing is a web client. The Ethernet library includes an example. The example only prints out the HTTP response. In your case you would need to read the response into a string buffer and then extract the file content from that. Reading the response into a string buffer is very similar to reading a message from the serial port into a string buffer and there are lots of examples of that. The part which will be unique to your project will be processing the string to locate the part containing the file content. You should be able to do that just by skipping the response header lines. This will be more obvious once you have run the example and seen what the response contains when you get the contents of the file.
