NanoESP32 cannot connect using WiFi.h
I am using the following sketch on an Uno R4 WiFi, where it works perfectly, and on a Nano ESP32 where it cannot connect to the WiFi. The arduino_secrets.h file is the same so it cannot be a password error and I have checked that the Nano ESP32 is allowed on the network via its MAC address. When uploading to the Nano ESP32 the monitor reads "Attempting to connect to WPA SSID: XXXXXXXXX .........."
I assume something is amiss with the WiFi.h library, doe anyone have a solution?
  ArduinoMqttClient - WiFi Simple Sender
  This example connects to a MQTT broker and publishes a message to
  a topic once a second.
  The circuit:
  - Arduino MKR 1000, MKR 1010 or Uno WiFi Rev2 board
  This example code is in the public domain.
#include <ArduinoMqttClient.h>
#if defined(ARDUINO_SAMD_MKRWIFI1010) || defined(ARDUINO_SAMD_NANO_33_IOT) || defined(ARDUINO_AVR_UNO_WIFI_REV2)
  #include <WiFiNINA.h>
#elif defined(ARDUINO_SAMD_MKR1000)
  #include <WiFi101.h>
#elif defined(ARDUINO_ARCH_ESP8266)
  #include <ESP8266WiFi.h>
#elif defined(ARDUINO_PORTENTA_H7_M7) || defined(ARDUINO_NICLA_VISION) || defined(ARDUINO_ARCH_ESP32) || defined(ARDUINO_GIGA) || defined(ARDUINO_OPTA)
  #include <WiFi.h>
#elif defined(ARDUINO_PORTENTA_C33)
  #include <WiFiC3.h>
#elif defined(ARDUINO_UNOR4_WIFI)
  #include <WiFiS3.h>
#endif
#include "arduino_secrets.h"
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = SECRET_SSID;    // your network SSID (name)
char pass[] = SECRET_PASS;    // your network password (use for WPA, or use as key for WEP)
// To connect with SSL/TLS:
// 1) Change WiFiClient to WiFiSSLClient.
// 2) Change port value from 1883 to 8883.
// 3) Change broker value to a server with a known SSL/TLS root certificate
//    flashed in the WiFi module.
WiFiClient wifiClient;
MqttClient mqttClient(wifiClient);
const char broker[] = "test.mosquitto.org";
int        port     = 1883;
const char topic[]  = "arduino/simple";
const long interval = 1000;
unsigned long previousMillis = 0;
int count = 0;
  //Initialize serial and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // attempt to connect to WiFi network:
  Serial.print("Attempting to connect to WPA SSID: ");
  Serial.println(ssid);
  while (WiFi.begin(ssid, pass) != WL_CONNECTED) {
    // failed, retry
    Serial.print(".");
    delay(5000);
  Serial.println("You're connected to the network");
  // You can provide a unique client ID, if not set the library uses Arduino-millis()
  // Each client must have a unique client ID
  // mqttClient.setId("clientId");
  // You can provide a username and password for authentication
  // mqttClient.setUsernamePassword("username", "password");
  Serial.print("Attempting to connect to the MQTT broker: ");
  Serial.println(broker);
  if (!mqttClient.connect(broker, port)) {
    Serial.print("MQTT connection failed! Error code = ");
    Serial.println(mqttClient.connectError());
    while (1);
  Serial.println("You're connected to the MQTT broker!");
  // call poll() regularly to allow the library to send MQTT keep alives which
  // avoids being disconnected by the broker
  mqttClient.poll();
  // to avoid having delays in loop, we'll use the strategy from BlinkWithoutDelay
  // see: File -> Examples -> 02.Digital -> BlinkWithoutDelay for more info
  if (currentMillis - previousMillis >= interval) {
    // save the last time a message was sent
    Serial.print("Sending message to topic: ");
    Serial.println(topic);
    Serial.print("hello ");
    Serial.println(count);
    // send message, the Print interface can be used to set the message contents
    mqttClient.beginMessage(topic);
    mqttClient.print("hello ");
    mqttClient.print(count);
    mqttClient.endMessage();
    count++;
on ESP32 WiFi.begin doesn't wait.
use
  WiFi.begin(ssid, pass);
    Serial.print('.');
