Hello all,
I'm attempting to use an arduino board to continuously detect a (only semi-accurate) peak frequency, with the hope of eventually having the frequency detected control some lights. I've been trying to do so using the below code, which I found from a tutorial on youtube, however whenever I run it, it will only print a frequency for maybe 10-15 lines, then it continuously prints nan's, until I reset the board.
Is there a way to continuously calculate peak frequency using MajorPeak() on an Arduino, without running into this NaN issue (or without having to reset the board everytime)? The code and equipment I'm using is posted below.
Equipment
Arduino Uno R3
Electrect Microphone Amplifier MAX4466 (powered by arduino board, 5V, and connected to A0)
Code
#include "arduinoFFT.h"
#define samples 128
#define Fs 2048
arduinoFFT FFT = arduinoFFT();
unsigned int FsPeriod;
unsigned long ms;
double vReal[samples];
double vImag[samples];
FsPeriod = round(1e6 * (1.0 / Fs)); //period in ms
for (int i = 0; i < samples; i++) {
ms = micros(); //num seconds since board began
vReal[i] = analogRead(A0); //Store Analog data
vImag[i] = 0;
// wait FsPeriod seconds
while (micros() < (ms + FsPeriod)) {
// do nothing
// Compute FFT
FFT.Windowing(vReal, samples, FFT_WIN_TYP_HAMMING, FFT_FORWARD);
FFT.Compute(vReal, vImag, samples, FFT_FORWARD);
FFT.ComplexToMagnitude(vReal, vImag, samples);
double peak = FFT.MajorPeak(vReal, samples, Fs);
Serial.println(peak);
delay(250);
Any other help on this is appreciated, as FFT and handling audio is a bit new to me. Thanks
