Narcolepsy
Hello
I am getting some errors with a program.
Errors:
sketch_nov14a.cpp: In function ‘void loop()’:
sketch_nov14a:61: error: ‘Narcoleptic’ was not declared in this scope
Here is my code:
#include <Servo.h>
#include <Narcoleptic.h>
A library that allows the microcontroller to go into standby
in times of inactivity, saving energy.
Servo myservo;
int Value;
int Center=105;
The variable Center represents the value of centering of
servo continuous rotation. In my case is 105.
  myservo.attach(9); // Connect the servo to pin 9
  int sensorValue = analogRead(A0);  // Read the value of the sensor LDR left
  int sensorValue2 = analogRead(A1); // Read the value of the sensor LDR right
  Value=(sensorValue-sensorValue2)/10;
   Calculates the difference between the two sensors and divides them for 10,
   in this way a difference of 10 is equal to 1, a difference
   of 53 is equivalent to 5 and so on
  if (Value==0) myservo.detach(); else myservo.attach(9);
  if (Value>10) Value=10;
  if (Value<-10) Value=-10;
   Limits the maximum difference between -10 and + 10
   (to avoid excessive speed)
  Serial.println(Value); // Debug - Displays the value on the serial
  myservo.write(Center+Value);
   If the value of Value is positive, move the Servo DX, if it is negative SX.
   The speed sould be directly proportional to the absolute value of Value
  Narcoleptic.delay(15);
 I'm using this to save energy.
Ultimately, I’m trying to make a servo follow the sun.
My Fritzing sketch is attached. Please help. Thanks!
Here's one error.
Mark
ebkapalka:
Hello
Errors:
Here is my code:
#include <Servo.h>
Servo myservo;
int Value;
int Center=105;
I’m using this to save energy.
Ultimately, I'm trying to make a servo follow the sun.
Looks like the narcoleptic library isn’t installed properly.
Code:
Here's one error.
Mark
Where? Not including braces and not indenting isn't an error.
Did you restart the IDE after installing the library? Did you install the library at all?
