Native Capacitive Sensors - Question
Thanks Bob for your answer
Anyway,
I tried to use it with a 10 meter cable ( telephone cable, 0.12mm) and it worked fine :slight_smile:
When I touch the cable end with a metal (or my fingers), I get a response on the serial port. Response is low but enough for me.
This is the Arduino code, Any suggestions?
thanks and cheers,
Y.
// sensor key
// code adapted from: http://arduino.cc/forum/index.php/topic,42592.0.html
#define KEYPORT PORTB
#define KEYDDR  DDRB
#define KEYPIN  PINB
#define KEY0    PB0        // capture input - digital 8
  Serial.begin(9600);      // connect to the serial port
// returns capacity on one input pin
// pin must be the bitmask for the pin e.g. (1<<PB0)
char getcap(char pin)
  char i = 0;
  KEYDDR &= ~pin;          // input
  KEYPORT |= pin;          // pullup on
  for(i = 0; i < 16; i++)
    if( (KEYPIN & pin) ) break;
  KEYPORT &= ~pin;         // low level
  KEYDDR |= pin;           // discharge
  return i;
void loop ()
  char capval;
  char pinval= {1<<KEY0}; // digital 8
    capval = getcap(pinval);
  if (capval>1){
    Serial.println(capval, DEC);
  delay(1);
