NAU7802
HI, I'm trying to get an external NAU7802 ADC to work via IC2. http://media.digikey.com/pdf/Data%20Sheets/Nuvoton%20PDFs/NAU7802_Preliminary.pdf
I have connected the device using the layout here.
http://qed.princeton.edu/main/Paulohno/private/assignment2 (the picture at the bottom)
But i'm having problems with the code.
Wire.beginTransmission(0x2A);
I am connecting to the address 0x2A, but apart from that i'm a bit lost can anyone take a look at the datasheet and give me any tips on the code or layout?
Thanks,
Cameorn.
What kinds of problems?
Why aren't you just using the NAU7802 library like the paulohno example?
Hi westfw,
Thank you for your reply!! I was getting worried that there wouldn't be any replies :S
The problem is that the NAU7802 library isn't available on that website :frowning:
So, I'm trying to do it myself but the datasheet is fairly complicated.
Thanks,
Cameron.
Hey Cameron,
Did you ever get this sorted out? Ie find the library?
I could really use it right about now.
thanks
