Components: MKR 1500 NB + MKR GPS shield
I am working on a NB signal strength tracker:
- get GPS point
- measure signal strength
- send information to server (JSON + MQTT)
The problem is that since the signal I am measuring is the same as I am using for transmission I am not able to assess areas without coverage. Thus the idea is to have a caching for the time no transmission is possible.
(for posting I have simplified and cleaned the code here below, not sure if it now works, but it should give the idea.)
// libraries
#include <MKRNB.h>
#include <Arduino_MKRGPS.h>
#include <TinyGPS.h>
#include <ArduinoMqttClient.h>
#include <ArduinoJson.h>
#define ARDUINOJSON_USE_DOUBLE 1
#include "arduino_secrets.h"
const char PINNUMBER[] = SECRET_PINNUMBER;
const char* APN = SECRET_APN;
const char* broker = SECRET_BROKER;
int port = SECRET_PORT;
// initialize the library instance
NBClient client; //NBSSLClient client;
MqttClient mqttClient(client);
GPRS gprs;
NB nbAccess(true); // include a 'true' parameter to enable debugging
NBScanner scannerNetworks;
NBModem modemTest;
TinyGPS gps;
// Save data variables
String errortext = "ERROR";
String pubTop = "boomJson";
String subTop = "control";
int sig;
String car;
int rat;
unsigned long epo;
int dist = 100; // measure every 'dist' meters
float la0 = 0;
float lg0 = 0;
float la;
float lg;
float alt;
float kmh;
int sat;
struct Config {
byte pubQos = 1;
byte subQos = 1;
//byte wilQos = 1;
String ICCID;
String carrier;
String simid;
String IMEI;
Config config; //make global
// initialize serial communications and wait for port to open:
delay(1500);
scannerNetworks.begin();
// Start module
bool connected = false;
while (!connected)
MODEM.begin(true); // true to restart the modem
while (!MODEM.noop());
MODEM.sendf("AT+COPS=0");
MODEM.waitForResponse(2000);
if ((nbAccess.begin(PINNUMBER,APN) == NB_READY) && (gprs.attachGPRS() == GPRS_READY))
connected = true;
} else
config.ICCID = modemTest.getICCID();
config.carrier = config.ICCID.substring(0,6);
config.IMEI = modemTest.getIMEI();
config.simid = config.IMEI.substring(6);
pubTop = pubTop + "/" + config.carrier + "/" + config.simid;
mqttClient.setCleanSession(false);
while(!mqttClient.connected())
MODEM.sendf("AT");
MODEM.sendf("AT");
mqttClient.connect(broker, port);
if (!GPS.begin()) { // GPS_MODE_SHIELD
Serial.println("Failed to initialize GPS!");
while (1);
while(GPS.available()==0);
epo = GPS.getTime();
la = GPS.latitude();
lg = GPS.longitude();
alt = GPS.altitude();
kmh = GPS.speed();
sat = GPS.satellites();
float distance_in_meters = gps.distance_between(la, lg, la0, lg0);
if(distance_in_meters > dist) // measure and send only if 'dist' to the last point is > 100 m
sig = scannerNetworks.getSignalStrength().toInt();
car = scannerNetworks.getCurrentCarrier();
StaticJsonDocument<212> msg;
msg["sig"] = sig;
msg["car"] = car;
msg["lat"] = la;
msg["lon"] = lg;
msg["alt"] = alt;
msg["kmh"] = kmh;
msg["sat"] = sat;
msg["epo"] = epo;
// do the transmission only if we have connectivity, if not cache/store and continue to measure and send the entire package as soon as connectivity is available again.
mqttClient.beginMessage(pubTop, false, config.pubQos);
serializeJson(msg, mqttClient);
mqttClient.endMessage();
// safe latest point location
la0 = la;
lg0 = lg;
} else
I am now not sure on how to handle that. i.e. a growing number of msg0, msg1,msg2 ... msgN. and than a for() loop to send the accumulated msg's. or to have a msg["sig"] = sig0,sig1...; kind of solution? But that would make the parsing at servers side a bit more difficult...
Any suggestions?
Thanks Matteo
