After a few hours of looking around I found the library and test code for this display.
But, I am not sure how to get it working…
I think I need to declare what pins I used? ( I went with 10 control pins + power as shown on the reference page)
Is this the location?
[color=#CC6600]Ncr4X20Vfd[/color] vfd(NCR_4X20_VFD_STROBE_PIN,
NCR_4X20_VFD_BUSY_PIN,
NCR_4X20_VFD_DATA0_PIN,
NCR_4X20_VFD_DATA1_PIN,
NCR_4X20_VFD_DATA2_PIN,
NCR_4X20_VFD_DATA3_PIN,
NCR_4X20_VFD_DATA4_PIN,
NCR_4X20_VFD_DATA5_PIN,
NCR_4X20_VFD_DATA6_PIN,
NCR_4X20_VFD_DATA7_PIN);
My other question is the Arduino (MEGA 1280) has two sets of pins 1-15, the analog ones and the digital ones, how do I specify which one is to be used?
Code that won’t compile:
Ncr4x20Vfd Library - Hello WorldDemonstrates use of the NCR 7454 / Futaba M204SD01B
4x20 VFD module.This sketch prints “Hello World!” to the LCD
and displays in seconds the amount of time the
sketch has been running.TODO: Insert link to wiring tutoral.
Reference page:
http://arduino.cc/playground/Main/Ncr4X20VfdHelloWorldOriginally created 6 Feb 2011
This file is in the public domain.
*/#include <Ncr4X20Vfd.h>
// See Ncr4X20VfdTutorialPins.h for other board defines.
#define NCR_4X20_VFD_ARDUINO_PINOUT
#include “Ncr4X20TutorialPins.h”Ncr4X20Vfd vfd(NCR_4X20_VFD_STROBE_PIN,
NCR_4X20_VFD_DATA7_PIN);void setup() {
// Drive the unneeded control lines high. The display’s parallel
// interface will not function correctly if they are low.
digitalWrite(NCR_4X20_VFD_RESET_PIN, HIGH);
digitalWrite(NCR_4X20_VFD_UNKNOWN_CONTROL1_PIN, HIGH);
digitalWrite(NCR_4X20_VFD_UNKNOWN_CONTROL2_PIN, HIGH);pinMode(NCR_4X20_VFD_RESET_PIN, OUTPUT);
pinMode(NCR_4X20_VFD_UNKNOWN_CONTROL1_PIN, OUTPUT);
pinMode(NCR_4X20_VFD_UNKNOWN_CONTROL2_PIN, OUTPUT);// Start the library.
vfd.begin();// Print an initial message on the VFD.
vfd.print(“hello, world!”);
}void loop() {
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
vfd.setCursor(0, 1);
// print the number of seconds since reset:
vfd.print(millis()/1000);// We delay here. Sending data continuously with no breaks can
// saturate the microcontroller on the display, preventing it from
// updating it’s output correctly.
delay(10);
