near-empty sub-subclass rejects initializer values, while subclass works
I have a dhDevice class, with subclass dhDeviceOut.
The nearly empty sketch attached compiles when allocating an array of dhDeviceOut.
dhDeviceOut sets ON and OFF as LOW and HIGH respectively, while my relay board uses the opposite, so the sub-subclass is declared simply to override those values.
Switching the active declaration to the relay subclass causes error “relay:4:47: error: conversion from ‘int’ to non-scalar type ‘dhRelay’ requested”
My library files are header dhTest.h
#ifndef dhMegaLib
#define dhMegaLib
#include "Arduino.h"
#include "SoftwareSerial.h"
#include "AltSoftSerial.h"
// some types to use
enum srlTyps {
  NONE, HARDWARE, SOFTSERIAL, ALTSOFTSERIAL
//possible status for the bt device
enum btStatStates {
  BTOFF, BTON, BTPOWERED, BTPENDING, BTAT
//an empty class that will get optimized out if used.
//this lets us keep our debugging code in the sketch
class nullSerial {
    void begin(void);
    void println(void);
    void print(void);
    int available();
    void read(void);
    void write(void);
    void end(void);
class dhDevice
public:
  dhDevice();
  //~dhDevice();
  // should these be declared virtual or somesuch?
  //turn on device with optional turnoff
  void dhDevice::turnOn(long runTime=0);
  //turn off device
  void dhDevice::turnOff();
  //report status
  // (shouldn't the return type be variable?  void doesn't make sense!)
  void dhDevice::reportStatus();
  void dhDevice::update();
class dhDeviceOut : dhDevice{
  public:
    dhDeviceOut(byte thePin);
    bool status();
    void turnOn(unsigned long turnOffTime=-1);
    void turnOff();
    unsigned long offTime();
    void update();
    byte pinReport();
  private:
    bool myStatus=false;
    unsigned long myOffTime;
    byte myOutPin;
    //default is to turn on with high, and off with low
    const byte ON=HIGH;
    const byte OFF=LOW;
class dhLed: dhDeviceOut {
class dhRelay : dhDeviceOut {
  private:
    //these boards use low to turn on
    const byte ON=LOW;
    const byte OFF=HIGH;
// a nibble function
byte eeNibble(unsigned int nibblePos) ;
#endif
and the cpp file:
// dhMegaLib.  dochawk's library of useful things for atMega projects.
// Copyright MMXIX
// a root device class from which to derive others
#include "dhTest.h"
#include "EEPROM.h"
//the base device
dhDevice::dhDevice(){};
//turn off device
//report status
//a subclass for output devices
dhDeviceOut::dhDeviceOut(byte thePin) : myOutPin(thePin){ }
void dhDeviceOut::turnOn(unsigned long turnOffTime){
              digitalWrite(myOutPin,ON);
              if (turnOffTime!=0){
                      myOffTime=turnOffTime;
                      //set to leave on indfinitely
                      myOffTime=0;
void dhDeviceOut::turnOff(){
              digitalWrite(myOutPin,OFF);
              myStatus=false;
	      myOffTime=0;
unsigned long dhDeviceOut::offTime(){
              return myOffTime;
void dhDeviceOut::update(){
              //update the current lights
              //for the moment, this assumes millis() will never overflow
              if( (myStatus==true) && (millis()>=myOffTime)) {
                      turnOff();
byte dhDeviceOut::pinReport() {return myOutPin;}
// a nibble function for the EEPROM
byte eeNibble(unsigned int nibblePos) {
  if (nibblePos % 2 == 0) {
    //even, high order nibble
    return EEPROM.read(nibblePos / 2) / 16;
    //odd, low nibble
    return EEPROM.read(nibblePos / 2) % 16;
I’m assuming that I"m missing something simple here.
relay.ino (279 Bytes)
Adding a constructor to pass the pin number to the parent constructor helps:
  public:
      dhRelay(int pin) : dhDeviceOut(pin) {};
Then constructing each before storing them in the array:
dhRelay sprinklers[] = {dhRelay(4), dhRelay(5), dhRelay(6), dhRelay(7), dhRelay(A2), dhRelay(A3), dhRelay(A4)};
//dhDeviceOut sprinklers[] = {4, 5, 6, 7, A2, A3, A4};
Maybe that's what I'm not understanding: I have (or at least think I do :) ) a constructor for the parent class:
Shouldn't this be inherited?
Or in the alternative, if that's not done correctly, shouldn't it fail to compile when switch which line is commented out?
Without the constructor for dhRelay I get this error:
ketch_feb21a:162:46: error: no matching function for call to 'dhRelay::dhRelay(int)'
With the constructor, the errors go away. I don't know why why the constructor doesn't seem to inherit.
This is what I got after merging the three files and working out the errors and warnings:
enum srlTyps
enum btStatStates
class nullSerial
    void begin(void);
    void println(void);
    void print(void);
    int available();
    void read(void);
    void write(void);
    void end(void);
class dhDevice
  public:
    dhDevice();
    //~dhDevice();
    virtual void turnOn(unsigned long runTime) = 0;  // PURE VIRTUAL
    //turn off device
    virtual void turnOff() = 0;  // PURE VIRTUAL
    // 'update' device
    virtual void update() = 0;  // PURE VIRTUAL
  public:
    bool status();
    void turnOn(unsigned long turnOffTime = 0);
    void turnOff();
    void update();
    byte pinReport();
  private:
    bool myStatus = false;
    const byte myOutPin;
    const byte ON = HIGH;
    const byte OFF = LOW;
  public:
    dhRelay(byte pin) : dhDeviceOut(pin) {};
  private:
    const byte ON = LOW;
    const byte OFF = HIGH;
// Copyright MMXIX
#include "EEPROM.h"
//the base device
dhDevice::dhDevice() {};
dhDeviceOut::dhDeviceOut(byte thePin) : myOutPin(thePin) { }
  digitalWrite(myOutPin, ON);
  if (turnOffTime != 0)
    myOffTime = turnOffTime;
    myOffTime = 0;
  digitalWrite(myOutPin, OFF);
  myStatus = false;
  myOffTime = 0;
  return myOffTime;
  if ( (myStatus == true) && (millis() >= myOffTime))
    turnOff();
  return myOutPin;
    //odd, low nibble
dochawk: Shouldn't this be inherited?
No, the constructors need to be explicitly defined for all classes, except for default and copy constructors.
