Nearly everything is working. Stepper motor via MQTT
Hi everyone. I have a project that I am working on that works as follows:
When started the leds light to check if they work.
I am using an OLED instead of termimnal to display messages, to check the code works properly.
When connected to WiFi and the MQTT broker the Blue LED lights.
I send a number between 1 and 5 via mqtt from my phone to a broker.
The ESP32 running arduino is a client, listening to the topic "Jumps".
When the message is recieved the stepper motor moves to one of 5 positions.
When the stepper reaches its position. the height is recorded into non volatile memory.
The battery level is checked and the appropriate LED turns on.
The part that I cant figure out is I want to push a button within a time frame at the start to recalibrate the lowest height if needed. It seems to see the delay but dosent go to the calibrate() function. There is a yellow led to turn on if it makes it to the function.The rest I have been able to figure out by looking at lots of tutorials. Can anyone see what i havent done properly?
Also I am sure that the code is probably not as efficient as it could be, so any suggestions to make it better would be appreciated.
Here is the code:
#include <EEPROM.h>
#include <WiFi.h>
#include <PubSubClient.h>
#include <Wire.h>
//SDA -> D21
//SCL -> D22
#define EEPROM_SIZE 1
//  ***************************** Set ADC pin for battery health  *****
const int Analog_channel_pin= 32;
//********************************Buttons ***************************************
const int buttn7 = 4;
const int buttn6 = 2;
const int buttn5 = 15;
const int buttn4 = 35;
const int buttn3 = 34;
//const int buttn2 = 39;
//const int buttn1 = 36;
//************************************* LEDS  ************************************
const int LedRed = 13;
const int LedYellow = 12;
const int LedBlue = 26;
const int LedGreen = 27;
//*************************************Stepper motor controller pins ************************
const int sleepPin = 19;
const int stepPin = 18;
const int dirPin = 5;
//************************************************ MQTT logon  ***********************
const char* brokerUser = "BRKRUSR";
const char* brokerPass = "XXXXXXXX";
const char* broker = "XXX.XXX.XXX.XXX";
const char* mqTopic = "Jumps";
int heightStored;
int j;
int k;
//***************************************** Variables for handling large number of pulses**********
unsigned long int i;
unsigned long int heightActual = 1000;
unsigned long int heightMove = 0;
unsigned long int stepActual = 0;
unsigned long int heightVal = 0;
unsigned long startMillis = millis();
unsigned long elapsedMillis;
int adcVal = 0;
float voltVal = 0;
int setCal;
int direction = 0;
int LedBlink = 750;
int stepPulseTime = 350;
int buttnCalVal;
int upBttn;
LiquidCrystal_I2C lcd(0x27,16,2);      //  Set LCD screen parameters
WiFiClient espClient;
PubSubClient client(espClient);
void calibrate()
    digitalWrite(LedYellow, HIGH);      //check if function called ************************************
    while (digitalRead(buttn7) == 1 || digitalRead(buttn5) == 1)
      if (digitalRead(buttn7) == 0)       // move up one pulse
          direction == 0;
          digitalWrite(stepPin, HIGH);
          delayMicroseconds(stepPulseTime);
          digitalWrite(stepPin, LOW);
        if (digitalRead(buttn5) == 0)     // move down one pulse
          direction = 1;
      return;
  pinMode(buttn7, INPUT_PULLUP);
  pinMode(buttn6, INPUT_PULLUP);
  pinMode(buttn5, INPUT_PULLUP);
  pinMode(buttn4, INPUT_PULLUP);
  pinMode(buttn3, INPUT_PULLUP);
  //pinMode(buttn2, INPUT_PULLUP);
  //pinMode(buttn1, INPUT_PULLUP);
  pinMode(LedRed, OUTPUT);
  pinMode(LedYellow, OUTPUT);
  pinMode(LedBlue, OUTPUT);
  pinMode(LedGreen, OUTPUT);
  pinMode(sleepPin, OUTPUT);
  pinMode(stepPin, OUTPUT);
  pinMode(dirPin, OUTPUT);
  //*********************************get previous stored value from  non volatile memory *********
  EEPROM.begin(EEPROM_SIZE);
  //********************************  Set stepper driver pins  *******************
  digitalWrite(stepPin,0);
  digitalWrite(dirPin,0);
  digitalWrite(sleepPin, LOW);                       // only enable when ready to move to save power
  //*****************************   System check *******************************
  digitalWrite(LedBlue, HIGH);
  delay(LedBlink);
  digitalWrite(LedBlue,LOW);
  digitalWrite(LedGreen, HIGH);
  delay(LedBlink);
  digitalWrite(LedGreen,LOW);
  delay(LedBlink);
  digitalWrite(LedYellow,LOW);
  digitalWrite(LedRed, HIGH);
  delay(LedBlink);
  digitalWrite(LedRed,LOW);
  //*********************************Start WiFi and LCD Screen ***********************************************
  lcd.begin();
  WiFi.disconnect();
  delay(100);
  // ******************************* detect button push for calibration
  elapsedMillis = millis();
  while(elapsedMillis < 8000)
  lcd.setCursor(0, 0);
  setCal = digitalRead(buttn7);
  if(setCal == 0)
      delay(2000);
      digitalWrite(sleepPin, HIGH);
      void calibrate();
  digitalWrite(LedRed, LOW);
  lcd.clear();
  adcVal = analogRead(Analog_channel_pin);   // read voltage on analog pin
  lcd.print("Battery Voltage");
  voltVal = (adcVal * 13.5) / (4095);   //    get battery voltage
  lcd.setCursor(5, 1);
  //lcd.print(adcVal);                   // get ADC Value
  lcd.print(voltVal);                    // get voltage value
  lcd.clear();
  //*************************************  Turn on WiFi  **********************
 lcd.setCursor(5, 0);
  lcd.print("START");
  WiFi.begin("ROUTER","XXXX");
  while ((!(WiFi.status() == WL_CONNECTED)))
    delay(300);
  lcd.clear();
  lcd.setCursor(3, 0);
  lcd.print("CONNECTED");
  lcd.setCursor(4, 1);
  lcd.print("TO WIFI");
  lcd.clear();
  lcd.setCursor(2, 0);
  lcd.print("YOUR IP IS:");
  lcd.setCursor(1, 1);
  lcd.print((WiFi.localIP()));
  lcd.clear();
  client.setServer(broker,1883);
  client.setCallback(callback);
void loop()  //***************   Main loop to run MQTTsever  *****
    if (!client.connected())
      reconnect();
  client.loop();
void reconnect()     //  ******************MQTT initialisation *******
    while(!client.connected())
      lcd.clear();
      lcd.setCursor(1, 0);
      lcd.print("CONNECT TO MQTT");
      if(client.connect("jump1", brokerUser, brokerPass))
        client.subscribe(mqTopic);
        digitalWrite(LedBlue, HIGH);        //Turn on LED to signify online
        lcd.clear();
        lcd.print("CONNECTING...");
        digitalWrite(LedBlue, LOW);
 void callback(char* topic, byte* payload, unsigned int length)
   payload[length] = '\0';                      // Make payload a string by NULL terminating it.
   int heightVal = atoi((char *)payload);       //convert to variable
   //*****************  check previous position when shut down ***********
   heightStored = EEPROM.read(0);
   lcd.clear();
   lcd.setCursor(4, 0);
   lcd.print(heightStored);   //Should be "MESSAGE"   <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
   //*****************************************************  Set pulses  to get correct height
   lcd.print(heightVal);
     if (heightVal == 1) {heightMove = 1000;}
     if (heightVal == 2) {heightMove = 2000;}
     if (heightVal == 3) {heightMove = 3000;}
     if (heightVal == 4) {heightMove = 4000;}
     if (heightVal == 5) {heightMove = 5000;}
     if (heightStored == 1) {heightActual = 1000;}
     if (heightStored == 2) {heightActual = 2000;}
     if (heightStored == 3) {heightActual = 3000;}
     if (heightStored == 4) {heightActual = 4000;}
     if (heightStored == 5) {heightActual = 5000;}
     if (heightMove > heightActual)                // if its higher, go up
       direction = 1;
       stepActual = (heightMove - heightActual);    // calculate how many steps to move between actual height of jump and new height
       direction = 0;                               // if lower, go down
       stepActual = (heightActual - heightMove);    // calculate how many steps to move between actual height of jump and new height
     if (heightMove == heightActual)                // check if same as last height
       loop();                                      // No movement. Back to loop
  digitalWrite(sleepPin, HIGH);                // only enable when ready to move to save power
  delay(100);
  digitalWrite(dirPin, direction);
     for(i=1;i<stepActual;i++)
  heightActual = heightMove;
  EEPROM.write(0, heightVal);   //  change value in non volatile memory for shutdown
  EEPROM.commit();
//*********************************************** Battery check *******************************
  delay(100);
     if(adcVal >  3800)
       digitalWrite(LedYellow, LOW);
     else if(adcVal <= 3800 and adcVal > 3300)
       digitalWrite(LedGreen, LOW);
Drop the void prefix when you call calibrate.
Thanks @wildbill. It was driving me nuts!
That fixed the issue, but it still dosent run the "while" statement in the function. Both buttons are pulled high. It seems to jump out of the loop instead of either going up or down depending on which button is pressed, or exiting if both buttons are pushed. Anyone have any ideas?
In case you are interested. this is the end result, although this is the old version with a button remote:
https://www.facebook.com/sfdab/videos/949379378515040
Start with posting your most recent code.
What while in what function?
In order to stay in the while loop the buttons must be pressed. The moment the user has to let the button become not depressed and the while loop read the not depressed before the while fails is very very short.
Its the while loop in the calibrate function. jst seems to go past it without running and returns to the setup function.
#include <EEPROM.h>
#include <WiFi.h>
#include <Wire.h>
//SDA -> D21
//SCL -> D22
const char* brokerUser = "BROKER";
const char* brokerPass = "PASSWORD";
int heightStored;
int j;
int k;
int adcVal = 0;
float voltVal = 0;
int setCal;
int direction = 0;
int LedBlink = 750;
int stepPulseTime = 375;
int buttnCalVal;
int upBttn;
void calibrate()
          direction == 0;
          direction = 1;
      return;
  delay(LedBlink);
  delay(LedBlink);
  delay(LedBlink);
  delay(LedBlink);
  lcd.begin();
  WiFi.disconnect();
  delay(100);
  if(setCal == 0)
      delay(2000);
      calibrate();
  lcd.clear();
  lcd.clear();
  lcd.print("START");
  WiFi.begin("SSID","PASSWORD");
    delay(300);
  lcd.clear();
  lcd.clear();
  lcd.clear();
      reconnect();
  client.loop();
      lcd.clear();
        lcd.clear();
   lcd.clear();
       direction = 1;
  delay(100);
  EEPROM.commit();
  delay(100);
     if(adcVal >  3800)
add in serial prints to see if the conditions are being met.
Thanks @Idahowalker. I`ll do it when i get home.
In the calibrate function remove return;.
void calibrate()
bool b7 = digitalRead(buttn7);
bool b5 = digitalRead(buttn7);
Serial.print( "b7 ");
Serial.print( b7 );
Serial.print( " b5 " );
Serial.print( b5 );
    while ( b7 || b5 )
          direction = 0; <<<< only needs on =!!!!!
          direction = 1;
        b5 = digitalRead(buttn5);
Note the change I made to the
I removed the bool declarations.
Thank you @Idaho walker for your response. That did the trick! It has taken months of researching to get this all working to the stage it was, and it was frustrating at the end to get so close and still not have it right. It works beautifully now :slight_smile: And my circuit boards arrive today, so I will be excited to get the jumps finished. I`ll post the finished code, in case anyone finds it useful. Theres loads of comments through it and probably some stuff that could be edited out, but hey, it works!
#include <EEPROM.h>
#include <WiFi.h>
#include <Wire.h>
//SDA -> D21
//SCL -> D22
int heightStored;
int j;
int k;
int adcVal = 0;
float voltVal = 0;
int setCal;
int direction = 0;
int LedBlink = 750;
int buttnCalVal;
int upBttn;
  delay(LedBlink);
  delay(LedBlink);
  delay(LedBlink);
  delay(LedBlink);
  lcd.begin();
  WiFi.disconnect();
  delay(100);
  if(setCal == 0)
      delay(2000);
      calibrate();
  lcd.clear();
  lcd.clear();
  lcd.print("START");
  WiFi.begin("SSID
","PASSWORD");
    delay(300);
  lcd.clear();
  lcd.clear();
  lcd.clear();
      reconnect();
  client.loop();
      lcd.clear();
        lcd.clear();
   lcd.clear();
       direction = 1;
  delay(100);
  EEPROM.commit();
  delay(100);
     if(adcVal >  3800)
void calibrate()
          digitalWrite(dirPin, HIGH);
          digitalWrite(dirPin, LOW);
      //return;
Also I did have the direction pin not set correctly. was supposed to be digitalWrite(stepPin, LOW or HIGH) to get the direction correct, not direction = 1 or 0 as was previously written.
