I have been attempting to flash an ESP8266 EP-01 with the example code Blink:
ESP8266 Blink by Simon Peter
Blink the blue LED on the ESP-01 module
This example code is in the public domain
The blue LED on the ESP-01 module is connected to GPIO1
(which is also the TXD pin; so we cannot use Serial.print() at the same time)
Note that this sketch uses LED_BUILTIN to find the pin with the internal LED
pinMode(LED_BUILTIN, OUTPUT); // Initialize the LED_BUILTIN pin as an output
// the loop function runs over and over again forever
digitalWrite(LED_BUILTIN, LOW); // Turn the LED on (Note that LOW is the voltage level
// but actually the LED is on; this is because
// it is active low on the ESP-01)
delay(1000); // Wait for a second
digitalWrite(LED_BUILTIN, HIGH); // Turn the LED off by making the voltage HIGH
delay(2000); // Wait for two seconds (to demonstrate the active low LED)
However, I keep getting a timed out packet header error:
Executable segment sizes:
IROM : 227612 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 26776 / 32768 - code in IRAM (ICACHE_RAM_ATTR, ISRs...)
DATA : 1252 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 672 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 24880 ) - zeroed variables (global, static) in RAM/HEAP
Sketch uses 256312 bytes (26%) of program storage space. Maximum is 958448 bytes.
Global variables use 26804 bytes (32%) of dynamic memory, leaving 55116 bytes for local variables. Maximum is 81920 bytes.
esptool.py v2.8
Serial port COM12
Connecting........_____....._____....._____....._____....._____....._____.....____Traceback (most recent call last):
File "C:\Users\jeffr\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.6.3/tools/upload.py", line 65, in <module>
esptool.main(cmdline)
File "C:/Users/jeffr/Documents/ArduinoData/packages/esp8266/hardware/esp8266/2.6.3/tools/esptool\esptool.py", line 2890, in main
esp.connect(args.before)
File "C:/Users/jeffr/Documents/ArduinoData/packages/esp8266/hardware/esp8266/2.6.3/tools/esptool\esptool.py", line 483, in connect
raise FatalError('Failed to connect to %s: %s' % (self.CHIP_NAME, last_error))
esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header
However, the code below:
// initialize digital pin LED_BUILTIN as an output.
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
flashes the WiFi chip in less than 30 seconds. Any clue why that is?
