necessary to get usb shield?
Hi-
I've just started experimenting with my Arduino Duemilanove. I've gone through the first two very basic experiments of controlling the built-in LED with code and then being able to turn on the LED with a pushbutton.
I'm sure this has been asked a million times before: How can I control and override my computer's keyboard with the Arduino? I want to build switches etc myself that make the computer think it's pressing a given key. I have very little electronic/programming experience, but I'm very interested in learning. Is it necessary for me to buy a USB shield? What's the easiest solution?
Thanks a lot for your help!
Well, if you bought or built some form of a USB shield, you would then have to emulate the keyboard as a USB HID (human interface device); since you are asking these questions, and state you have little programming experience, doing so would be a no-go at this point in your skillset, so I wouldn't bother right now (just know that it is possible).
You could (if your motherboard supports it) interface via the PS/2 port; still, there would be a fair amount of coding to do that might be beyond your level.
Here's a few links:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1213375969/5
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1258067608/5
If you are using Windows, there is a program out there (that I can't seem to find now) that can run on the PC, and listens for commands from the USB serial device (the Arduino, in this case), and then virtually "presses" the keys for you on the machine (can somebody help me here?)...
Hope this helps!
:slight_smile:
cr0sh,
I believe gobetweno is what you had in mind.
novum,
I have not played with gobetweno, but it looks like a good option. It's free and requires no extra hardware.
As is stated in every post like this which people would see if they searched (yes the search works now so that's not an excuse!)
AACKeys...
Mowcius
hari, yes - that is what I had in mind; I just came back over here to see if anybody posted it, because someone on another thread did and I was thinking "that's what it's called!"...
Thanks for posting it!
