Hi I am planing on building a remote controlled rover/ robot. However I am having difficulty calculating the torque.
I get about 500 oz-in or about 3.5Nm, I am wonder if that is a reasonable number for a robot with these specs:
Weight - 40lb (weight per wheel 6.25lb)
Max incline - 15 degrees
Desired speed of 2 m/s (6.6 ft/s) -- at about 200 rpm
An acceleration time of 2 secs
A wheel radius of 4 inches
A rolling resistance on grass - about 0.08
I plan on having a 4 drive motor set up, one for each wheel, will a motor like this one work and be able to pull the load as well as have a fast enough rpm http://www.omc-stepperonline.com/dual-shaft-cnc-stepper-motor-nema-24-100mm-4nm566-ozin-24hs393008d-p-388.html? Also are there any cheaper and lighter solutions for this? I want to use steppers to estimate the distance traveled but It seems as though half the robot's weight will end up being motors, just compounding the need for a greater torque.
I make it about 4.4Nm for 15 degree incline - total for all wheels, so 1.1Nm per wheel.
Multiply by a safety factor for friction/gears/rolling resistance, call it 2Nm per wheel
You don't want to use a stepper motor for traction, use standard DC gearmotors, otherwise
you'll have no efficiency to speak of and very short battery life.
With 20:1 reduction gearing that would be a 4000rpm motor with 0.1Nm torque per wheel,
ie about 40W per wheel.
Thanks for the help. However I am still having difficulty finding a motor, do you have any recommendations? I have spent an hour or so looking on eBay with no luck. What site can I find the motors on?
I have looked around on Aliexpress and think I have had some success. If you wouldn't mind it would be a great assurance if any of these would work before I buy them.
