Ned Help Pls
Hi, I am a beginner in arduino, in really ned help to make a program with to fade a led, e
and switch it on of, with two buttons. can anyone help me with the code ? button1 turn ON, and fade op. Buttun two fade down and turn off.
Have you worked through any of the examples provided in the IDE?
Yes some of theme, but i i need learn more, think its so difficult.
int Led = 5;
int switch1 = 7;
int switch2 =8;
pinMode(5,OUTPUT);
pinMode(7,INPUT_PULLUP);
pinMode(8,INPUT_PULLUP);
if(digitalRead(7) == LOW) Led--;
if(Led < 0) Led = 5;
if(digitalRead(8) == LOW) Led++;
if(Led > 255) Led = 255;
analogWrite(5, Led);
delay(30)
i did this one for fade, but now how to turn it on and off, with the switches
fabregas:
int Led = 5;
int switch1 = 7;
int switch2  =8;
  pinMode(5,OUTPUT);
  delay(30)
Please use code tags.
Using appropriate variable and constant names will help you figure out what's wrong.
Use 'const int ledPin = 5' and 'int brightness = 0' for example.
You probably mean: 'if(Led < 0) Led = 0;'
You declared variables for input pins, but you didn't use them. Also, they should be constants.
Pieter
