Hi, I was told to try posting this here...
I need to sample three audio signals, each roughly 34k samples/second, so I want to sample ADC at around 100kHz. I started by using the Due's built-in ADC, which seemed like it was fast enough, but I was getting bad results. From what I could tell, this was because of switching between analog inputs too quickly. I'm open to other solutions, but here's what I'm doing now:
Now I have a MCP3008 ADC chip and am trying to get it working with the Arduino SPI library. I got it working with this library GitHub - nodesign/MCP3008: MCP3008 - Analog to digital converter Arduino library which bit bangs it. I'm under the impression the SPI library would be faster, does this sound right? The issue I'm having is that SPI.transfer() is only returning 1's, not any useful results, and I cannot figure out why.
Here's a bit of my latest code from trying to debug this. I've tried using the Due's extended library, adding delays all over the place, setting the SPI clock as low as I can, etc., but none of it seems to be working. Every time I try all I get back is a lot of 1's and nothing else.
If anyone could help with this I would really appreciate it, I'm out of ideas on this. I'm also open to suggestions on better ways to get fast ADC from multiple (3) sources. Thanks!
Wiring:
Vdd -> 3.3V
Vref -> 3.3V
AGND -> GND
CLK -> 13
Dout -> 12
Din -> 11
CS -> 10
DGND -> GND
CH0 -> 1V (for testing, should return adc value of ~307)
#include <SPI.h>
#define CS_PIN 10
#define CLOCK_PIN 13
#define MOSI_PIN 11
#define MISO_PIN 12
SPI.begin();
SPI.setBitOrder(MSBFIRST);
SPI.setDataMode(SPI_MODE0);
Serial.println("BEGIN");
digitalWrite(CS_PIN, LOW);
int commandout = 0;
commandout |= 0x18; // # start bit + single-ended bit
commandout <<= 3; // # we only need to send 5 bits here
byte result1 = SPI.transfer(commandout);
byte result2 = SPI.transfer(0x00);
byte result3 = SPI.transfer(0x00);
Serial.println(commandout);
Serial.println(result1, BIN);
Serial.println(result2, BIN);
Serial.println(result3, BIN);
Serial.println("done");
digitalWrite(CS_PIN, HIGH);
