need a bit of help please
hi nearly done writing my first code but got stuck at the end trying to work out how i can make the second if statement only blip the mossfet pin once and not reset again until analog values return to the fired state
const int linearChipsPin = A0; // declaring in put for linear actuator to be arduinoA going to ao on arduinoB
const int mossfetPin = 9; // declaring mossfet out put pin from arduino b to be pin d9
const int hallbPin = A2; // declaring in put for hallback sens from trigger of controller
const int autoPin = A4; // declaring rotary switch auto pos to pin a4
const int semPin = A6; // declaring semi auto pin for rotary switch a5
pinMode(mossfetPin, OUTPUT);
int hallValue = analogRead(hallbPin); // declaring hallValue = analog read of hallback sensor on pin 9
analogRead(hallbPin); // declaring analog read of hallPin
int linValue = analogRead(linearChipsPin); // declaring linvalue = analog read off linear actuator on pin a0
analogRead(linearChipsPin); // declaring analog read of linearChipsPin A0
int autoValue = analogRead(autoPin); // declaring autoPin = AutoValue
analogRead(autoPin); // declaring analog read off Auto pin
int semValue = analogRead(semPin); // declaring semValue = analog read of semPin
analogRead(semPin); // declaring analog read of sem pin
if ( hallValue < 180 && (autoValue > 500) && (linValue > 250) )
digitalWrite(mossfetPin, HIGH);
delay(50);
digitalWrite(mossfetPin,LOW);
delay(50);
digitalWrite(mossfetPin, LOW);
if ( hallValue < 180 && (semValue > 500) && (linValue > 250) )
delay(50);
delay(10000);
Serial.println(semValue);
delay(1);
Your codes are slightly revised and posted below; compare these codes with your original codes and judge if the changes make sense.
 // analogRead(hallbPin);                 // declaring analog read of hallPin
 // analogRead(linearChipsPin);           // declaring analog read of linearChipsPin A0
  //analogRead(autoPin);    // declaring analog read off Auto pin
 // analogRead(semPin);  // declaring analog read of sem pin
    delay(50);
   // digitalWrite(mossfetPin, LOW);
   // delay(50);
    delay(50);
    //digitalWrite(mossfetPin, LOW);
    //delay(10000);
  delay(1);
thanks for the reply, not to sure i do understand still isnt doing my program intent tho in the firs if if the varibles are met it should blip the mossfet until the retern back to there normal state and in the second if , if the varibles are met im trying to get it to only bllip once apoligies for the spelling school wasnt my thing.
Imagine you have a variable:
boolean shouldBlipMosfetThisTime = false;
and you can set it to true or false at any point in your code. And you can test it in an if statement wherever. Can you envision how to use that to get what you want?
jordo22233: school wasnt my thing.
A piss poor excuse...
Delta_G: boolean shouldBlipMosfetThisTime = false;
Is there any good reason to prefer boolean to bool when both can be used interchangeably in Arduino IDE?
thanks :slight_smile:
const int autoPin = A5; // declaring rotary switch auto pos to pin a4
int currVal = 0;
int prevVal = 0;
bool setPinHigh = false;
unsigned long startTime = 0;
unsigned long onTime = 0;
//(linValue > 250
if ( hallValue < 180 && autoValue > 500 && linValue > 500)
delay(50);
delay(50);
if(semValue > 500 && linValue > 300 && prevVal <= 300 && hallValue < 180)
setPinHigh = true;
delay(50);
setPinHigh = false;
if(setPinHigh && millis() - startTime < onTime)
setPinHigh = false;
prevVal = linValue;
delay(1);
Please use code tags. Read the forum rules if you don't know what that means. You should have read that before you started posting.
