Need A Computer Program That Sends Mail With Arduino Trigger.
I need A Windows Program That sends a mail to configured mail address when a sensor triggers the arduino the Program need mail send function to Gmail. Please give some Idea. Also Please dont suggest Gobetwino , I already tested It and Found Some Bugs in The Software and also it cannot send mail to Gmail. Thanks.
Why do you need a Windows program? If it works, the Arduino will work. I send email to my gmail account with my ethernet shield. http://playground.arduino.cc/Code/Email The email sending block is normally by ip address ranges. If one fails in that ip range, probably all ips in that subnet range will fail to send email.
ganeshkubade: I need A Windows Program That sends a mail to configured mail address when a sensor triggers the arduino the Program need mail send function to Gmail. Please give some Idea. Also Please dont suggest Gobetwino , I already tested It and Found Some Bugs in The Software and also it cannot send mail to Gmail. Thanks.
I can write a program for you, but I don't have that much free time =D.. A quick google search came up with a processing sketch of sending emails using a gmail POP/SMTP server. And another google search came up with how to setup your gmail with a POP/SMTP server =D..
Processing sketch: http://www.shiffman.net/2007/11/13/e-mail-processing/ Gmail to POP/SMTP: https://support.google.com/mail/troubleshooter/1668960?hl=en#ts=1665119,1665162
//Basel
@basilsw: Neither of those links do a bit of good for an Arduino, except for basic theory.
I am lucky. I have my own SMTP server that my ISP seems to love (takes the load off their server). If this becomes a problem, many recommend SMTP2GO for that kind of stuff.
Well, I didn't say that it's a complete solution.. It's a good start-point.. You'd have to change a couple of things in the processing sketch, like adding serial capability (there is a library for that, use google) and setup some kind of communication "protocol" for the serial com between arduino and processing (like if serial.read equals 1 send a email with the following message, etc).
But like I said, you'd have to do a little work (YAYY =D). Otherwise I hope someone else here have some other kind of solution for you..
Good luck =)
//Your friendly neighbourhood spider-man
Hi , baselsw Thanks for Given Info I will Try it and reply , Thanks again.
I try to send Email with my arduino Due with ethernet shield.
I use the sketch : "Email client sketch for IDE v1.0.1 and w5100/w5200 Posted December 2012 by SurferTim" found in this forum
But does'nt work.... I got on the serial monotor:
Ready. Press 'e' to send. connected
Timeout (from the sub-routine eRcv) Email failed
Any sugestion......thank a lot.....
Alain
@Prof: Post your code. I know it is from the playground, but a few changes needed to be made by you, and I want to check them.
Here is my code:
#include <SPI.h>
#include <Ethernet.h>
// this must be unique
 byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// change network settings to yours
 IPAddress ip( 192, 168, 0, 198 );
 IPAddress gateway( 192, 168, 0, 1 );
 IPAddress subnet( 255, 255, 255, 0 );
// change server to your email server ip or domain
// IPAddress server( 1, 2, 3, 4 );
char server[] = "mail.navigue.com";
 EthernetClient client;
   pinMode(4,OUTPUT);
   digitalWrite(4,HIGH);
   Ethernet.begin(mac, ip, gateway, gateway, subnet);
   delay(2000);
   Serial.println("Ready. Press 'e' to send.");
   byte inChar;
   inChar = Serial.read();
   if(inChar == 'e')
       if(sendEmail()) Serial.println("Email sent");
       else Serial.println("Email failed");
 byte sendEmail()
   byte thisByte = 0;
   byte respCode;
   if(client.connect(server,25)) {
     Serial.println("connected");
     Serial.println("connection failed");
     return 0;
   if(!eRcv()) return 0;
   Serial.println("Sending hello");
// change to your public ip
   client.println("My public IP");
   Serial.println("Sending From");
// change to your email address (sender)
   client.println("MAIL From: <pif_paf_pouf@hotmail.ca>");
// change to recipient address
   Serial.println("Sending To");
   client.println("RCPT To: <arduino1967@hotmail.ca>");
   Serial.println("Sending DATA");
   client.println("DATA");
   Serial.println("Sending email");
   client.println("To: You <arduino1967@hotmail.ca>");
// change to your address
   client.println("From: Me <pif_paf_pouf@hotmail.ca>");
   client.println("Subject: Arduino email test");
   client.println("This is from my Arduino!");
   client.println(".");
   Serial.println("Sending QUIT");
   client.println("QUIT");
   client.stop();
   Serial.println("disconnected");
   return 1;
 byte eRcv()
   byte respCode;
   byte thisByte;
   int loopCount = 0;
   while(!client.available()) {
     delay(1);
     loopCount++;
     // if nothing received for 10 seconds, timeout
     if(loopCount > 20000) {
       client.stop();
       Serial.println("\r\neRcv-Timeout");
       return 0;
   respCode = client.peek();
   while(client.available())
     thisByte = client.read();
     Serial.write(thisByte);
   if(respCode >= '4')
     efail();
     return 0;
   return 1;
void efail()
   byte thisByte = 0;
   int loopCount = 0;
     delay(1);
     loopCount++;
       client.stop();
       Serial.println("\r\nefail-Timeout");
       return;
   client.stop();
I work on it last night and my first error was to don’t have the good mail server name (mail.navigue.com)
NOw I get that message on arduino monitor :
Ready. Press ‘e’ to send.
connected
220 mail.navigue.com ESMTP Postfix
Sending hello
502 5.5.2 Error: command not recognized
221 2.0.0 Bye
disconnected
Email failed
I thnk I don’t send the right command to my mail server ?
Thank again for your help…very appreciate…
It is failing at this send:
   // change to this
   client.println("helo 1.2.3.4");
It is best to put your public ip there instead of 1.2.3.4.
edit: Your next problem should be it will not take email for a hotmail account. If you want to send email like this, it needs to be sent to the email server that handles the email for that domain.
GReeeaaaattttt.....working now :D
I was putting my public IP in that line .....but not the "helo" before it.
That was the problem......
Thank a lot SufferTim...... great job you're doing....
Thanks! :)
It seem then my email server handle Hotmail domain. Make two différents mail in lthe last minute.....and work well. :D
Thank again
If I want to have the message on my cellular phone ?
I will have to use a program like Twitter or Hotmail can do that ?
If it relays to Hotmail, then that would usually indicate the email server for that domain is an open relay. That is not a good thing. Spammers will use it to relay spam all over the place.
If you have an email account monitored by your cellphone, you should be able to send email to it. If you want to send a text message (SMS), then read this post: http://forum.arduino.cc/index.php?topic=157013.msg1202024#msg1202024
Thank for the post for the SMS.
But about the spammers (then i really don’t like) a way exist to avoid spammers ?
The spam prevention part is up to the owner of the SMTP server. Unless it is yours, there is not much you can do about it.
To complete this post.
Now I able to send data from my Arduino to my Email account.
Able to send data in SMS to my cellular.
For the user of Telus mobility go there http://mobility.telus.com/fr/QC/send_message/index.shtml
to see how send SMS to your cell from a email account
Thank to you SurferTIm and all the community.....again.....very appreciate and great job...
