Hi. I'm working on a little project with a dc motor and a L293D. I want the dc motor to spin at a low speed (40 RPM). The motor I have works at 100 RPM but it hardly works below 80-90 RPM and it doesn't work at all at 40 RPM. Is there a (cheap) dc motor who works at 40 RPM? I've searched in the net but I didn't find one (I'm quite newbie, by the way).
I've tried with a very simple program (below). I change the speed value and it works fine with high values but it seems that the motor I have can't work with low values. I work with Arduino Mega 2560, a dc motor and a L293D.
// Motor connections
int enA = 9;
int in1 = 8;
int in2 = 7;
// Set all the motor control pins to outputs
pinMode(enA, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
// Turn off motor - Initial state
digitalWrite(in1, LOW);
digitalWrite(in2, LOW);
musikakutxa();
void musikakutxa() {
analogWrite(enA, 100); // Doesn't work with low values
// Turn on motor
digitalWrite(in1, HIGH);
delay(20000);
// Turn off motor
With this program (I work with Arduino Mega 2560, a dc motor and a L293D).
int enA = 9;
int in1 = 8;
int in2 = 7;
musikakutxa();
// Turn on motor
delay(20000);
// Turn off motor
The big problem with the L293 is that it is a very old design and uses transistors in a Darlington pair to switch the positive and negative power to the motors. This means that the voltage available to drive your motor is down by between 2 and 4 volts on what you put in as a power source.
You have not mentioned what voltage you are trying to use, but my guess is that you do not have enough voltage, once you start to apply PWM, for the motor to turn.
This can be cured by getting a proper modern driver that uses FETs instead of (bipolar) transistors.
The problem with small (and cheap) DC motors is that they aren't very good at low speed, 40 rpm is less than 1 rpm. They rely on a commutator to switch current from one rotor coil to the next and at low speed this is pretty discontinuous and there isn't enough rotor inertia to keep it spinning smoothly. If you do want a low rpm, as suggested in post #2 a geared motor is better - then the actual motor bit is working at a speed where it runs smoothly and you have gearing to get the output shaft speed. The type shown are very nice but there are lots around at probably lower prices.
