Jimmy60:
Why not just set the led timer on a button press and ignore releases? It all about handing the reading of the switch. Think of a switch as a signal that can either be LOW or HIGH and every time through loop() you check for a change from the last known signal state. If there is a change you start the debouncing timer. If the debouncing timer is set (non-zero) then you can see if it has been in that state long enough to be a valid state change (passes debouncing). Then you can act on the state, knowing it's a valid change. I think for your purposes you should just ignore button releases. Start timing the LED on presses.
By timing the led on presses it will automatically reset for another cycle any time it is pressed. Basically like the debounce timer. Then you can check for the LED timer being set and handle the LED switching.
// Your problem is that you have to focus your attention first on reading the button.
// Once you do that properly handling the LED is quite trivial.
// Handling the button properly means detecting state changes and debouncing
// use constants for pin numbering
// ALLCAPS style denotes global constant
const byte SWITCH_PIN = 2;
const byte LED_PIN = 13;
const unsigned long DEBOUNCE_TIME = 20UL;
const unsigned long LED_ON_TIME = 1000UL * 60UL * 5UL; // 5 minutes
// global variables to handle switch reading
unsigned long debounceTimer = 0;
int switchState;
// for LED timing
unsigned long ledTimer = 0;
boolean ledOn = false;
pinMode (SWITCH_PIN, INPUT_PULLUP);
switchState = digitalRead(SWITCH_PIN);
pinMode (LED_PIN, OUTPUT);
unsigned long currentTime = millis();
int currentSwitchState = digitalRead(SWITCH_PIN);
if (switchState != currentSwitchState)
switchState = currentSwitchState;
debounceTimer = currentTime;
if ((debounceTimer > 0) && (currentTime - debounceTimer >= DEBOUNCE_TIME))
debounceTimer = 0;
if (switchState == HIGH) // released
// nothing to do on button release
else // switchState == LOW pressed
// start the timer for the LED
ledTimer = currentTime;
if (ledTimer > 0)
// check for LED turn on
if (!ledOn)
digitalWrite(LED_PIN, HIGH);
ledOn = true;
// check for LED turn off
if (ledOn && (currentTime - ledTimer >= LED_ON_TIME))
digitalWrite(LED_PIN, LOW);
ledOn = false;
ledTimer = 0;
That ignores releases so if you hold the button for longer than five minutes it will turn off at five anyway. To reset the led timer the button has to be released then pressed again. I think that represents fairly typical operation of such a button.
First of all thank You for Your help
But in this case my led turns off if I have the button pressed,
and I need wen pressed to be on (as long as it is pressed)
and off after a 5min delay (after released)
best regards
thank You once again
