Folks seem to be constantly tripping over interrupt vector conflicts in libraries that want to make use of AVR interrupts that Wiring doesn't handle. The common culprits are: NewSoftSerial, NewPing, IRremote, Tone and probably dozens of others. Searching the forums for '"multiple definition of" __vector' will turn up a lot.
There's room for improvement in the diagnostics on these, but it does require establishing some best practices. How about if library developers were encouraged to do something like this?
#if ISR_2_INUSE
# error Library NewFrobnitz requires use of ISR2, but it is used by ISR_2_INUSE
#else
# define ISR_2_INUSE NewFrobnitz
#endif
That would allow the CPP to generate a more sensible error describing the conflict straight off, and would lead to less frustration from end users.
