need a global variable defined that constantly changes
ok i have a feeling this might be simple but i cannot get my head around it
i am trying to make a simple pwm file which , for learning purposes will only use the 8 bit timer
along with PIN D6 (OCOA)…the code for that looks like thislooks like this
#ifndef fastPWM
#define fastPWM
void iniPWM()
	TCCR0A |= ((1<<COM0A1) | (1<<WGM01) | (1<<WGM00)) ; //set to use pin d6 and set to fast pwm
	TCCR0B |= ((1<<CS02) | (1<<CS00)) ; //set the prescaler
	TIMSK0 |= ((1<<TOIE0));// set timer overflow interrupt .. not sure if its is propper to use interrupts in files outside of main program
void startPWM (  )
	OCR0A  =((pulseWidth / 100) * 255.0); // set  output compare to a percentage of 255
ISR (TIMER0_OVF_vect)
	OCR0A  =((pulseWidth / 100) * 255.0); //after the first interrupt this should just keep going and going
#endif
now my problem is i need to pass a pulsewidth in my main code if i use #define pulsewidth then i cant change the pulse width
and if i use a regular deffinition then its not seen by the pwm library…
my main code looks like this
#define F_CPU 16000000L
#include <avr/io.h>
#include <eddie/fastPWM.h>
#include <avr/interrupt.h>
int pulseWidth = 50;  // <--here is the problem
int main(void)
	sei();
	iniPWM();
    while(1)
	startPWM();
i know i can set the start pwm function to accept a parameter but then how do i get the ISR routine to also see that parameter if ISR accepts no parameters , only way would be to have a global variable , but then i cant change it…feels like a catch 22 , but im sure its just lack of knowledge…
can anyone enlighten me
furthermore is malpractice to use interrupts inside a .h file?
i know .h files are for definitions only , i will soon be attempting to learn about libraries . i just want to test out what can be done in an .h file
only way would be to have a global variable , but then i cant change it....feels like a catch 22 , but im sure its just lack of knowledge..
Why can't you change it? If it can't be changed, it's not a variable, right?
However you might want to make it volatile:
volatile int pulseWidth = 50;
Definitely, you will be hearing from my lawyers. :P
You should use .h files for declarations, and .cpp files for code.
