I am working on a buoy project and need to measure vertical displacement. I need a faitly accurate IMU for this because even small inaccuracies can lead to huge drift when integrating acceleration. Budget for IMU is less than 200 USD. Are there any good IMUs you would reccomend?
I don't have any experience in the area, but if you don't need any fixed reference, would it be enough to measure vertical displacement relative to a running mean?
The buoy is not going to be moored, it's free-floating, so there isn't a consistent, fixed reference point to measure against. I would measure the displacement relative to a running mean. But the only way I know of is using the IMU's vertical acceleration and performing double integration over time to obtain the displacement, and comparing the buoy's position, derived from the double integration, to a running mean. That is why I need a fairly accurate IMU. The IMU will eventually drift as suggested by the other users. But there are ways of correcting the drift. I just haven't gotten that far yet.
There is an issue because you need the absolute vertical displacement to determine the wave heights. If both the IMU readings and the running mean drift significantly from the true vertical displacement of the buoy, then the wave height measurements will be inaccurate.
It's been a while since I read the papers. I had to take some time off for personal reasons.
The project is to create a small low-cost wave buoy that can be used to determine wave heights. Traditionally, wave buoys are very large, heavy and expensive. They are difficult to deploy and take up too much space. I want to create something similar to this, without costing a fortune. Spotter Buoy by Sofar
The goal is to eventually have an open-source low-cost buoy that is cheap enough to be deployed whenever and wherever. The buoys will estimate wave heights, take measurements and upload everything to a website. More sensors will be added eventually, like c02, pH, temperature etc for water quality. But that part is easy. The difficult part is to get accurate wave estimations without spending 2k on an IMU. Its difficult but it definitely can be done.
I will do some more research and post the links I find.
Yes, because I am asking advice on which IMU to get. Theres no problem yet, there will be in the future though, but I need to start somewhere. I currently only have the GY-86 which is not good enough.
I know members here have tons of expertise and invaluable experience and probably played around with different IMUs. I want to know what's the best IMU I can get for around 200 USD.
