Need a list of all the CAN0.xxxx function calls
Is there a manual of all of the MCP2515 function calls such as
CAN0.begin
CAN0.checkReceive
CAN0.readMsgBuf
CAN0.getCANId
CAN0.sendMsgBuf
CAN0.checkError
etc.?
I have definitions for the above six function calls but can't find anything on others (i.e. ones I don't even know exist so I don't know what they are to ask about them or search for them).
If you are using a library than you can look in the .h and .cpp files where you will find all of the functions available.
Thank you. Being a complete muppet here! I did look in the .h and .cpp files but I was expecting to find something defined as CAN0.xxx
If I ignore the 'CAN0' part then all of the functions (e.g. begin, sendMsgBuf, etc.) are defined in "mcpcan.cpp" and "mcpcan.h"
I was confusing the function call with what I thought the function should be named.
So now that you have found the function definitions are you OK ?
The function name IS, for instance, sendMsgBuf(). It is CALLED on an instance, of some mysterious, though we could guess) class, that is called CAN0.
Yes, thank you, I am OK now that I have found the definitions.
