Need a little help with Eagle, to many switches!
99% of the time I use 3 switches that I may want to mount on a PCB…
1 Standard Double Pole Slide Switch (For panel mounting - 2xM3 threaded fixing holes. Distance between hole centres 28mm)
2 SPDT Miniature toggle switch.
3 Tactile switch 6x6mm
And I cant find any of them in Eagle!!! ;D
Alas, such things are far from “standardized” and come with a bewildering array of mounting and pad options. The most likely candidate look like the “tiny switch” options in the switch library (which are lacking the usual DPDT or SPDT designations.)
Probably like the ones in the switch-omron library?
That for that westfw.
I guess if i keep buying the same switches it make seance to make my own part for them in eagle…mmmmm…off to the tutorials! :smiley:
Try getting the sparkfun eagle library, it is full of a load of parts. Might include what you are looking for.
Mowcius
