Need a low-flow sensor for liquid measurement
For a project, I want to select low-flow sensor that can measure liquid from as low as 5ml/hr to 100ml/hr or higher. Can anyone suggest me arduino compatible sensors for this purpose? I have seen a sensor from Sensirion but I'm not sure if its compatible with Arduino or not.
Looking forward to hearing from you all.
How thick is the tube it is going to flow through?
RushanArshad:
Post a link to its datasheet
...R
Kevin77:
Its a few mms. Basically a catheter.
Robin2:
...R
Heres the link to its datasheet. https://www.sensirion.com/fileadmin/user_upload/customers/sensirion/Dokumente/Liquid_Flow_Meters/Sensirion_Liquid_Flow_Meters_LD20_Preliminary-Datasheet_V1.pdf
Quote from the datasheet
Digital communication between a master and the LD20sensor runs via the standard I²C interface.
That should work fine with an Arduino.
I was hoping they might be suitable for measuring diesel fuel - but I doubt it.
...R
volume is not velocity.
volume is the result of velocity times area.
most velocity sensors have a range in which they are accurate and you may need to alter your area (duct size or pipe diameter) in order to get the velocity into the best range for the sensor.
thermal flow sensors are very accurate at slow velocities and loose resolution at higher velocities.
the mass sensors usualy come in fixed pipe diameters and offer you a way to select by choosing volume.
Robin2:
...R
Yes this should be fine with water and other liquids but not fuels. They have not mentioned that they are compatible with Arduino so thats why i have a confusion.
Hi Rushan,
I wrote Arduino drivers for Sensirion flow sensors, which should support the LD20 sensor: GitHub - winkj/arduino-sflow: Unoffical arduino driver for Sensirion flow sensors.
Note that if you're using a 5V Arduino, you may have to use a logic level shifter (e.g. https://www.sparkfun.com/products/12009) as the LD20 is spec'ed at 3.3..3.7V only.
winkj:
Hi Rushan,
Thank You very much brother. Have you worked with these LD20 sensors? Which are other options of low flow sensors? I was searching from where to buy in UK, so if you could tell e from where can i buy and price?
RushanArshad:
I worked with the LS32-1500, which should be compatible.
For purchasing options it’s best to ask the local representation of the manufacturer of the part you want to buy; they’re gonna be in the best position to help with that.
Anyony knows where to buy the ld20?
