Need a sensor to measure weight
I need a sensor to measure weights from 5lb to 100lb Can anyone suggest me with one?
Flexible sensor would be preferable.
ebay..: eg this type ?
That wont do. I need flexible sensors like FSR’s
Then use FSRs!
The problem is i get force readings from FSR, but i need readings in weight. I dont know how to get that and I am also not sure whether FSR could be used to get weight readings.
weight of object = force exerted by Earth’s gravity on object
FSRs don't measure tension.
A tension loadcell is what you are looking for I think. Perhaps if you explained exactly what you are trying to do we could avoid the xyproblem here? Tension loadcells are expensive.
