Need a small help with pyfirmata
Hi, I am trying to connect pyfirmata with Arduino for getting the HC-SR04 sensor data.
PS: StandardFirmata is uploaded to the board already
from pyfirmata import *
import time
port ='COM5'
baud = 57600
board = ArduinoMega(port, baudrate= baud)
trigpin = board.get_pin('d:2:o')
echopin = board.get_pin('d:3:i')
start=0
end=0
trigpin.write(0)
time.sleep(5)
while True:
    trigpin.write(1)
    time.sleep(3)
    trigpin.write(0)
    while echopin.read(0):
        pass
        start = time.time()
    while echopin.read(1):
        pass
        end = time.time()
    print((end-start)/58.0*1000000)
    time.sleep(1)
But it seems its not working at all. Says:
Traceback (most recent call last):
  File "D:\Codes\Research\pyth\us.py", line 26, in <module>
TypeError: read() takes 1 positional argument but 2 were given
Circuit connection
You should be testing the return value of read(), not passing in what you want the return value to be...
while echopin.read() == 0:
You also do not need those pass statements since you have other statements inside your while loops
