Hi, I have a need to remotely control an Arduino Nano. By "remote" I mean 2 or 3 ft, but it has to be wireless. Ideally the transmitter should be as compact as possible, it just need to have a button that allow one to toggle different mode on an Arduino program.
I did some study on this:
RF 315/433 MHz Transmitter-receiver Module
I wonder if there are even smaller options? The above transmitter will get pretty big if you hook it up to a Nano and with an antenna. Especially the antenna, I don't want 20 cm of wire dangling. Do I even need an antenna for such a close distance?
Ditch the nano and use two Wemos D1 minis. Or, a Zigbee (or Xbee) with trace antenna may do what you need without any uC. Also, plastic enclosure=no problem for any of these.
paulwece:
So fit the Nano, transmitter and battery in the smallest box you can find and the loosly coil an insulated wire antenna inside the box. I would be amazed if it did not cover 3ft when built like that.
