To start, i'm fairly well versed in 120V electrical, but ICs and such are unfamiliar territory for me right now. (i do have some basic experience with Arduino)
A few years ago i got my hands on a vintage DJ Ufo style light, it was missing the halogen bulb and both motors were shot, as well as almost all of the lenses had lost their color.
It's been thrown around a lot as i tried to restore it fully, but now i've decided to change routes, and i want to rebuild it as a modern fixture.
I would like to first remove all the wiring and redo it for 12V and remove the color film from the last 2 lenses(which is easy enough)
Once that is done I'd put a (preferably) high power RGBW-A-UV LED behind EACH lens instead of using a single halogen bulb. This light fixture has 14 lenses so i'd need 14 LEDs
But i would like to control each LED separate from the others, as well as having full dimming/color mixing in order to make some intense effects, but i have absolutely no clue how to handle that,
From what i've seen Addressable LEDs are too dim for the scale i need.
I found a LED chip i like, But with 6 inputs (RGBWA-Uv) * 14 lenses gives me 84 separate signals.
I know i'm in a bit over my head, but this will be a fun project, i just need help.
i'm not as concerned about money at this time (although i will not just buy a "new" DJ ufo light)
I could really use suggestions on everything.
I am willing to settle for just RGBW chips, but i NEED them to be bright enough to create beam effects when paired with smoke effects (the glass lenses should help a lot here)
I would also like to put in something like stepper motors, and control them as well, but if it's too much to add them i can just use simple constant speed 12V motors
But right now i'm just concerned with figuring out the ideal light/controller combo, but i will try to detail the entire end planso you all can understand my thought process:
Firstly, the "Head" of this fixture is currently completely hollow, so i have some space to work with inside, but i would like to have the Arduino in the base of the machine and run a handful of wires up through 2 slip rings into some kind of decoder in the head that splits the input signal into the 84 separate wires that go to each LED chip. but i do think i might be able to fit the arduino in the head
As for the LED chip i want RGBW+Uv, but i couldn't find any that did not also have Amber, so that's what i'm going with (again, open for suggestions, i have not bought any parts yet)(i suppose i could just not connect the Amber to save 14 wires total) (maybe could use seperate RGBW and Uv chips?)
the motors i am not currently concerned with but ideally i would replace the 2 AC motors with some strong 12V steppers (maybe ones with an optical encoding for precise precision control)(i guess here would be the spot to point out this fixture has infinite rotation on both Axis, so i can't tell it to rotate until it stops to calibrate it)
For the software side i wanted to break it up into:
Rotation patterns,
Rotation pattern speed,
Color Patterns,
Color Pattern Speed,
ideally i would use a webpage or a DMX interface to control these settings so i don't need to do a full reprogram just to change a color theme for a holiday. but again. all i am concerned with now is the hardware side of things. i just thought explaining my plan could help.
sorry if this post seems scattered, i have a lot of troubles translating my thoughts into words so i need to type each thought as it happens,
