Need advice on connector, pic of project box inside
As I get closer to putting my project in this box, I need some kind off two pin connector to carry the WS2812B LED signal and ground lines.
Standard power type barrel plug? 1/8" phono connector? I need something that won't short out one pin to the other when I'm unplugging or plugging it (which should be done with the unit off, but things happen).
As I get closer to putting my project in this box, ....
So where s the pic?
Use the same connector as the WS2812B ?
You don't need to use a 2 pin connector, you just need to use 2 pins on a connector and there is a whole world of connectors out there.
