Dear experts,
I ame using the SdFat lib on a arduino duemilanove + ethernetshield to read some data from a file to a char array.
problem: When i print out the char array via serial.print.... the char array is empty...
ex. here i load and store the data from the file to my stuct array..when i print out here then it works..however:
while ((n = rdfile.fgets(line, sizeof(line))) > 0) {
if(i<10)temp*.packetBuffer = line;*
Serial.println( temp_.packetBuffer ); // here there is data_
* i++;*
... if i print out after the while then there is no data in my temp struct (i belive this may be caused by the pointer...if this is the case can anyone give me some hint to a workaround?):
for(int j =0; j<10; j++)
* Serial.print( "Data " );*
* Serial.print( j );*
* Serial.print( ": " );*
_ Serial.println( temp[j].packetBuffer ); // here there is no data_
can anyone help me out or even give me some hint on some better way if possible?
I am using the demo code followed with the Sdfat lib.... I will appriziate any help i can get...thanks in advance
*// Demo of fgets function to read lines from a file.
#include <SdFat.h>
SdFat sd;
// print stream
ArduinoOutStream cout(Serial);
typedef struct tprofiles
char *packetBuffer;
}tprofiles;
tprofiles temp[10]; // struct array to hold the data i read out from the file
// store error strings in flash memory
#define error(s) sd.errorHalt_P(PSTR(s))
void demoFgets() {
char line[250];
int n,i=0;
// open test file
SdFile rdfile("FGETS.TXT", O_READ);
// check for open error
if (!rdfile.isOpen()) error("demoFgets");
cout << endl << pstr(
"Lines with '>' end with a '\n' character\n"
"Lines with '#' do not end with a '\n' character\n"
"\n");
// read lines from the file
if(i<10)temp[i].packetBuffer = line;
Serial.println( temp[i].packetBuffer ); // here there is data
i++;
Serial.print( j );
void makeTestFile() {
// create or open test file
SdFile wrfile("FGETS.TXT", O_WRITE | O_CREAT | O_TRUNC);
if (!wrfile.isOpen()) error("MakeTestFile");
// write test file
wrfile.write_P(PSTR(
"name#1#2#3#4#5#6#7#8#9#10#11#12#13#14#15#16#17#18#19#20#21#22#23#24#25#26#27#28#29#30#31#32#33#34#35#36#37#38#39#40#41#42#43#44#45#46#47#48#49#50#51#52#53#54#55#56#57#58#59#60#61#62#63#64 \n"
"name1#1#2#3#4#5#6#7#8#9#10#11#12#13#14#15#16#17#18#19#20#21#22#23#24#25#26#27#28#29#30#31#32#33#34#35#36#37#38#39#40#41#42#43#44#45#46#47#48#49#50#51#52#53#54#55#56#57#58#59#60#61#62#63#64 \n"
// wrfile is closed when it goes out of scope
void setup(void) {
cout << pstr("Type any character to start\n");
while (!Serial.available());
// initialize the file system
if (!sd.init(SPI_HALF_SPEED, 4)) sd.initErrorHalt();
makeTestFile();
demoFgets();
cout << pstr("\nDone\n");
void loop(void) {}
_```*_
