See post 22
Really really low to no power = non-active device
Sounds like something for RFID.
avr_fred:
Really really low to no power = non-active deviceSounds like something for RFID.
I know for sure that there is no rfid module or simple ic for a longer range then 5cm, i need more the 2meters
And it doesn't have to be secured or unique, the secured message is transmitted after!
I know my english is bad and i may explained it badly, ask if you didn't undersand anything!
Is it too much trouble to push a button?
jremington:
Yes :d
prologikus:
Yes :d
Then use reply #1.
aarg:
Then use reply #1.
Be more detalied... What module should i use? When i hear rfid i'm only thinking of RC522 module that is not what i need from any point of view, if you thought of suggesting it then you should read my post again
the receiver on my keychain can't be a simple, 433mhz module receiver, it's consuming too much power
A more complex receiver will consume more power. Receivers are power hungry.
jremington:
Ye... But there are a lot modern cars and home automation systems that did it.
I'm wondering that this does
LTC5507
I only need to detect a rf signal from 2m with a very low quiescent current so then i can send the true rf message
jremington:
LTC5507 Datasheet and Product Info | Analog Devices
I know but i still don't understand what it does..
Technical English...
The LTC5507 is a very insensitive, extremely broadband receiver that detects basically all radio frequency signals, from 100kHz to 1 GHz. Your local AM and FM radio stations and cell phone towers will all activate it.
Similar to a "crystal radio".
jremington:
The LTC5507 is a very insensitive, extremely broadband receiver that detects basically all radio frequency signals, from 100kHz to 1 GHz. Your local AM and FM radio stations and cell phone towers will all activate it.Similar to a "crystal radio".
But according to it's datasheet i can adjust the frequency to what i need, right?
The chip is not selective. You can approximately set a lowest frequency to be detected.
prologikus:
Are there ?
Can you provide us with examples and the details of how much power these receivers use ?
srnet:
Are there ?Can you provide us with examples and the details of how much power these receivers use ?
Some Bmw key have it audi opel but can't find any info about their ics
jremington:
What does this mean? It means that it will active whenever it receives the calculated freq or all the freq that are lower that it?
Is there any ic with a more precise freq range so i can send a random 433mhz signal and wake up the arduino from the key
All frequencies equal to or higher than the lowest selected, activate the LTC5507.
jremington:
So for example i'll need a higher freq emitter then 2.4ghz so it won't trigger the arduino on every wifi, is this right?
(other ic)
jremington:
A couple of years ago I built a simple field strength meter using this device. Works on HF and VHF frequencies for me. Drives a fairly large analog meter.
Paul
