Need advices on storing serial monitor data
Hello everyone..
I am working on a project and I get vast amount of Serial monitor data. I need to analyze it, so I better use some tools. :slight_smile:
My plan is simple: storage whole data to excel and analyse it by excel support.
However, to do that, I need to put the data to excel.
I made some short research and concluded to 2 options.
  1. Learn "Processing", convert the code to this language and add necessary codes to storage data.
  2. Use some programs which storages serial monitor data directly.
I tend to prefer the second option because I won't need to learn another language and I won't need to disturb my code. However, I don't know the advantages and disadvantages of both options.
Should I really prefer the second option or does using "processing" a better option for something that I am realize yet?
And, If I prefer second option, which program you would you suggest?
(except Twedge, I need more than 90 days and I can't afford paying a program)
Thanks
You do not identify your PC OS ... but generally most Serial Communication programs can log to a file. Why, oh why, the ArduinoIDE does not is beyond me, but it is Open Source so I am not going to complain because someone will just tell me to add the write-to-file log code :o
You can also do it by redirecting the serial port to a file if you are into that command-line stuff.
Click Here for Google Search
Processing terminal code: https://www.safaribooksonline.com
/library/view/arduino-cookbook/9781449399368/ch04.html
Ray
https://www.google.com/search?q=gobetwino
However, I prefer Python for such things. I believe Robin2 has graciously published an example on this forum.
I use Jack Christensen's 'Serial Data Monitor'.
http://forum.arduino.cc/index.php?topic=281091.0
Any good free terminal emulator like PuTTY or even HyperTerminal on Windoze will allow you to send and write files. Don't use serial monitor, use a terminal program.
... snakes make me squeamish :cold_sweat:
I have never used gobetwino ... probably should give it a try for my own edification.
Ray
Windoze
:frowning:
LarryD:
Windoze
:frowning:
OMG ... not cross-platform!
I'm a No-Windoze kind of guy ... I even take NoDoz when I drive if I can't get the liquid caffeine.
Once I was a MCSE, but W-10 broke me down into a shadow of the hacker I once was ... then I was saved by Linux. Amen
Ray
I am using Realterm software to create excel files now. :slight_smile:
Thank all of you very much..
