Below this text is an small "schema" how I want it to work with lego train and leds. The trafficlights are made By leds. I don´t need a complete code just what kind of components (sensor) and perhaps
some advice about the programming to code and other things. I'm using Arduino Uno for this Project.
1 Stop the train with sensor at trafficlights 1 and trigger trafficlights 2 to switch from green to red.
2. When trafficlights 2 is switched to red then trigger trafficlights 1 to switch from red via yellow to green.
3. Train start when trafficlights 1 is switched to green and another sensor trigger trafficlights 1 to switch from green via yellow to red.
4. When trafficlights 1 is red then switch trafficlights 2 from red to green.
Therefore you need to implement the Lego IR protocol in the Arduino.
I did reverse engineer this protocol for a book I wrote:-
So I can't publish it here because of copy write with the books publishers, but it is not difficult. The book has code in Python for the Raspberry Pi but the protocol is the same.
It is the same protocol used in the IR controller for the EV3 mind storms system.
Grumpy_Mike:
I did reverse engineer this protocol for a book I wrote:- Raspberry Pi Projects For Dummies | Wiley
Thanks for this advice. I have obtained the book and it seem to be very interesting book.
