Hi Everyone,
I need your suggestions on best resistive/conductive material which has following properties to be used as a exposed to human body potentiometer:
Tensile strength like hard plastic
Scratch resistivity
Linear conductivity
Preferably in the form of thin sheet (<=0.3 mm)
No health risk
As an example, I recently tried 3d printing a thin sheet using conductive PLA spool but my problem with that was lack of resistance linearity across the sheet.
Can you tell more about your project ? What are you going to make ?
Something with a flat surface and X, Y coordinates ?
You have high demands ! And that's not all. Should it also be corrosion proof ?
How did you measure the resistance ? You could drill tiny holes in it and use tiny screws. That will make good contact.
Sometimes a simple copper wire or copper sticky tape will do.
You can get copper clad fiberglass sheet as thin as you like. Think printed circuit board material. That would fit all your requirements, as stated, with no other parameters being given.
Paul
Then there is the possibility of roughing up the surface a bit and coating with graphite powder. That would work on plastic sheet. But who knows what the OP has planned.
Paul
What are you trying to sense? Have you measured the resistance of finger tips after they have been playing a violin/cello? Bet they are completely dry and have VERY high resistance.
Paul
Sorry that was not clear enough. Violin/cello strings are part of the circuit. So sensing happens when string touches finger board. Something like what you see in the image:
I think trying to use a resistive sensor is the wrong way to go. It will, in my experience never be consistent enough. But if you want to try then look at a linear “soft pot”. See Soft pot
I think you would be better off with one or several of these. https://bela.io/products/trill/
The long thin ones can be mounted end to end.
I recently made a MIDI guitar with two of these sensors, although I did divide the fretboard into frets in software rather than a continuous sensor.
Video at https://www.youtube.com/watch?v=-22KG11FD_s
The strings are conductive then?
As this is a linear application isotropy presumably isn't a requirement, so I'd suggest carbon fibre, although its pretty conductive its less conductive than metals.
With fingers involved you have the problem that the circuit includes a human, so the low impedance may actually be of benefit in rejecting inteference from the finger.
Hey Mike,
You are right about trill sensors in terms of consistency, I've got one of them. but forming these sensors as a real violin/cello fingerboard regarding curves etc., seems impossible.
I watched your videos, Awesome work!
