Hello, I have built a 8x8 button matrix and I believe I properly wired them up.
This is what I came up with
const int g_column[] = {8 pins here};
const int g_row[] = {8 pins};
bool state[8][8] = {0};
for (int i = 0; i < 8; i++) {
pinMode(g_column[i], OUTPUT);
pinMode(g_row[i], INPUT);
pinMode(LED_BUILTIN, OUTPUT);
while (!Serial) {
delay(100);
digitalWrite(LED_BUILTIN, HIGH);
work();
delay(100);
void work() {
for (int column = 0; column < 8; column++) {
digitalWrite(g_column[column], HIGH);
for (int row = 0; row < 8; row++) {
bool val = digitalRead(g_row[row]);
if (val != state[column][row]) {
state[column][row] = val;
String action = "";
if (val) action = "press";
else action = "release";
String str = "Button " + action + " Column: " + String(column) + " Row: " + String(row) + "\n";
Serial.print(str);
digitalWrite[g_column[column], LOW];
Now what this does is when I press a button at one row, it triggers for each column.
Doing a quick google search led me to this code which worked while testing.
I don't know what is wrong with my implementation and staring at it for half an hour didn't provide me an answer so here I am. What did I do wrong?
J-M-L
May 20, 2021, 8:01pm
#2
try with
digitalWrite(g_column[i], HIGH);
pinMode(g_row[i], INPUT_PULLUP);
and inversion of all the states including default value is HIGH and make it LOW one by one and test against LOW to see a press
void work() {
digitalWrite(g_column[column], LOW);
String action "release";
if (!val) action = "press";
String str = "Button " + action + " Column: " + String(column) + " Row: " + String(row) + "\n"; // what a waste of memory... just do multiple print
Serial.print(str);
Hi, @noideaplusplus ,
one of the correct ways to define an array looks like this:
(Replace the numbers with the ones you need to use in your project.)
const int g_column [] = {1,2,3,4,5,6,7,8};
const int g_row [] = {11,12,13,14,15,16,17,18};
RV mineirin
J-M-L
May 20, 2021, 8:27pm
#4
gond point - I had assumed the OP had changed this to match his setup...
I do have my pins set up correctly, that's how I copied it when sending here.
I don't know why but even after reversing the default values, it's still same.
guix
May 20, 2021, 9:22pm
#6
You have a problem on this line :
digitalWrite[g_column[column], HIGH]
You used square brackets instead of parenthesis
And I'm surprised that it compiles without errors, can someone explain why ?
I have been looking at the same code expecting some kind of logic error for hours now, turns out it's a mistype. I need to get my eyes checked.
J-M-L
May 20, 2021, 10:18pm
#8
I have not checked if it compiles at all or without warning, did you? (I’m on my mobile)
(A function name is also a pointer, so may be (a big maybe) with the array notation you can get to a few bytes further in memory. I will be seen as digitalWrite[1]
and then as it’s a useless statement it’s thrown away by the optimizer…)
system
Closed
September 17, 2021, 10:18pm
#9
