Need assistance with esp8266
So essentially, I have my esp8266 and I am trying to open an http server, however, whenever i put the ip address of http://10.0.0.146/, it just says site cannot be reached or something along the lines of that. Basically, my project is sending commands from the ip server to my robot which will do tasks, but the main problem I have currently is actually opening the ip server. Also, it opens once in a while, but usually it just says "this site cannot be reached. Any help would be appreciated. Thank you!! (im new to the forum so lmk if i didnt post correctly)
#include "WiFiEsp.h"
#include "SoftwareSerial.h"
SoftwareSerial softserial(4, 5);  // RX, TX
char ssid[] = " ";      // your network SSID (name)
char pass[] = " ";  // your network password
int status = WL_IDLE_STATUS;
int reqCount = 0;  // Number of requests received
WiFiEspServer server(80);
  // Initialize serial for debugging
  // Initialize serial for ESP module
  softserial.begin(115200);
  softserial.write("AT+CIOBAUD=9600\r\n");
  softserial.write("AT+RST\r\n");
  softserial.begin(9600);
  // Initialize ESP module
  WiFi.init(&softserial);
  // Check for the presence of the shield
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println("WiFi shield not present");
    while (true) ;
  // Attempt to connect to Wi-Fi network
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to WPA SSID: ");
    Serial.println(ssid);
    status = WiFi.begin(ssid, pass);
  Serial.println("You're connected to the network");
  printWifiStatus();
  // Start the web server on port 80
  server.begin();
  // Listen for incoming clients
  WiFiEspClient client = server.available();
  if (client) {
    Serial.println("New client");
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.write(c);
        // If an HTTP request ends
        if (c == '\n' && currentLineIsBlank) {
          Serial.println("Sending response");
          // Send HTML form with buttons to control the robot
          client.print(
            "HTTP/1.1 200 OK\r\n"
            "Content-Type: text/html\r\n"
            "Connection: close\r\n"
            "\r\n"
            "<!DOCTYPE HTML>\r\n"
            "<html>\r\n"
            "<h1>Control Robot</h1>\r\n"
            "<form action=\"/moveForward\" method=\"GET\">\r\n"
            "<input type=\"submit\" value=\"Move Forward\">\r\n"
            "</form>\r\n"
            "<form action=\"/stop\" method=\"GET\">\r\n"
            "<input type=\"submit\" value=\"Stop\">\r\n"
            "</form>\r\n"
            "</html>\r\n");
          // Check the incoming request for a command and send it to the robot
          String request = client.readStringUntil('\r');
          if (request.indexOf("/moveForward") != -1) {
            sendCommandToRobot("MOVE_FORWARD");
          } else if (request.indexOf("/stop") != -1) {
            sendCommandToRobot("STOP");
        if (c == '\n') {
        } else if (c != '\r') {
          currentLineIsBlank = false;
    delay(10);  // Allow time for data to be sent
    client.stop();
    Serial.println("Client disconnected");
void sendCommandToRobot(String command) {
  // Send the command to Robot Arduino through serial (pins 1 and 0)
  Serial.println(command);  // Debugging output
  Serial.println("Command sent to Robot: " + command);
void printWifiStatus() {
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  Serial.print("IP Address: ");
  Serial.print("To see this page, open a browser to http://");
https://github.com/JAndrassy/WiFiEspAT?tab=readme-ov-file#Why-a-new-wifiesp-library
I read it, but i don't what exactly to do with that information lol. But thank you!
