I would like to use SD_MMC because it supports larger cards and is supposedly faster. Examples I find are apparently for earlier versions of the ESP32 and not specific to the S3 and the S3 seems to be different.
Is it true that I can basically use any pins I want? I need normal SPI to work with a TFT monitor and would like to use SD_MMC for SD access. I would assume that I could use the same CLK pin for both SPI and SD_MMC. I don't know how clean the various libraries are (setting SS -only- before access and resetting it immediately after) so I am thinking it would be best to have MISO/MOSI completely separate from D0, D1, D2, D3 and CMD.
One difference on using the SD_MMC with the S3 seems to be that it is mandatory to call SD_MMC.setPins before calling SD_MMC.begin.
Does anyone have an example of using SD_MMC with the ESP32 S3?
My 64GB card says it is formatted with exFAT. Is that correct and if not, what should it be formatted to?
Thanks.
