need braces when adding char to struct?
Hello
I get this error:
"error: array must be initialized with a brace-enclosed initializer" for ATIME tOn = {hh, mm, time};
it won't let me add the char time: 06:10 to the struct, and I can't see why. If I add the string directly then it works, but thats not what I want.
typedef struct {
  byte hour;
  byte minute;
  char time[6];
} ATIME;
ATIME alarms[4];
void setupTime() {
   byte hh=6;
   byte mm=10;
   char time[6];
   char t[6] = "06:10";  // for testing
   for(byte i=0; i < 4; i++) {
     strcpy(time, t, sizeof(t));
     ATIME tOn = {hh, mm, time};  // this fails
//    ATIME tOn = {hh, mm, "06:10"};  // this works
      Serial.println(tOn.time);
      mm = mm + 10;
      alarms[i] = tOn;
  setupTime();
  Serial.println("-----");
  Serial.println(alarms[0].time);
Can anyone help
Thanks
Karl.
You can't copy arrays like that (using 'time'), use a loop and do it element by element.
You could use something like that
typedef struct {
  byte hour;
  byte minute;
  char time[6];
  void setIt(byte hh, byte mm, char* txt) {
    hour = hh;
    minute = mm;
    strncpy(time, txt, 6);
} ATIME;
ATIME alarms[4];
void setupTime() {
  byte hh = 6;
  byte mm = 10;
  char time[6];
  for (byte i = 0; i < 4; i++) {
    sprintf(t, "%02d:%02d", hh, mm);
    alarms[i].setIt(hh, mm, t);
    //     strcpy(time, t);
    //     ATIME tOn = {hh, mm, {time}};  // this fails
    Serial.println(alarms[i].time);
    mm = mm + 10;
  setupTime();
Probably it would be wise to store only the integers in the alarm structure
(better for consistency and the size of an alarm shrinks from 8 to 2 byte)
and generating the string representation on demand in a supplied buffer.
Structures can have memberfunctions just like classes.
karl101:
Can anyone help
Here is some example code dealing with struct array:
struct ATIME {
  byte hour;
  byte minute;
  char time[6];
ATIME alarms[4]= {
  {8,20,"08:20"},
  {9,30,"09:30"},
  {19,0,"19:00"},
  {20,45,"20:45"},
  Serial.println("Original values:");
  // Now set all vakues different by using code
     alarms[i].hour=6;
     alarms[i].minute=10;
     strcpy(alarms[i].time,"06:10");
  Serial.println("Changed values:");
BTW: You seem to keep a lot of redundant information in your struct, this is wasting RAM and requires extra programming to keep all redundant information logically consistent!
