Hi. I want to say the following:
if x ! (<70 && >5)
digitalWrite (LED, HIGH);
in words: I want LED to light if x is not between 5 and 70. I do need to use the “not” function because if I use a function like if x >70 || x <5 I do not get the LED to light if x = nan (like my temperature sensor got disconnected)
karotto:
if x ! (<70 && >5)
Thanks much
The entire expression must be within the parenthesis and your syntax is incorrect. But your premise is not entirely correct because every such expression has a complement that can be expressed without the negation:
if (not (x <70 && x>5) )
can be:
if (x >= 70 || x <= 5)
How a failed reading is reported depends on the sensor library code.
C provides >, <, ==, !=, <= and >= to compare numbers.
C provides parenthesis for grouping
C provides !, &&, and || to combine logical operators.
There isn’t a range function like “5 <= x <= 70” to check if x is between 5 and 70.
So, to check if a number is between 5 and 70, you use
(x >= 5) && (x <= 70)
To check the converse of this, x isn’t between 5 and 70 (inclusive)
