need code
i use i load cell 50 kg AD620AN res. 10ohm and arduino uno
and connect it
code it to see my result ?
What code have you tried? There is a section of the forum called Gigs and Collaborations where you can get someone to write the code for you, but they generally want to be paid for it. Here you can get help with your code, but it requires most of the effort to be on your part.
"How to use this forum. 6. Make a meaningful subject line
Try to summarize your problem with a helpful and informative subject line. Helpful subjects draw in people who might know the answer. Unhelpful ones are likely to be skipped."
