Hey guys,
I'm working on the software for a signal processing project.
Currently the project uses an MSP430. The circuit was designed about 7 years ago. The best MSP430 only has a few kilobytes for storing code, so I'm fighting a lot with it because of this. I'd like to switch to something Atmel based.
Requirements:
- Low power. Microcontroller currently consumes about 3uA averaged out in a day. The whole project board runs off of a 9V battery.
- I'm writing software to process signals from an accelerometer. The events last about 5 minutes, occur 5-10 times a day. (this is to get an idea of the averaged power consumption that is possible by placing the controller in a sleep mode).
- Currently using a 10-bit ADC. Input signal is 0-2V @ 2kHz.
- 4 outputs, 6mA.
- The cost of our current controller is $2.05 at 1000. Would like to use an Arduino project for fast development, and translate that into something that is cheap and low power. Up to $4/unit is acceptable.
- Would be great to have a microcontroller that satisfies these requirements and also interfaces with an SD card for debugging/data logging.
Mostly looking for 1) Which Arduino version would work for software development, 2) What Atmel controller should I be looking at moving to for production?
arusr,
Yes to both of your questions. So I take it you'd suggest the ATMEGA328 satisfies all the requirements?
I just discovered Energia, an Arduino branch for MSP430. I'm torn between the two now -- not sure which is going to make for easier software development in the long run. I do know that using Energia will save me time in porting the code over to the AVR.
nycto:
arusr,
You mention that the reason for switching is to get more memory. Energia isn't going to help you with this.
Other than the SD card (which I didn't look into because I have no experience with this), I would think an UNO would be fine.
If you have a working system with the MSP430, I would suggest you just get a bigger MSP430 so you don't have to rewrite everything.
Also, do you really only use 3uA of current per day? That's an impressive number...
Sorry, I meant that its average consumption over the day is 3uA, so 72uAh in about a day.
Are you sure? TI comes out with new versions of the MSP430 on what seems to be a daily basis. The "1" series has 60 kB of code space and up to 10 kB of RAM. The "2" series has 120 kB of program memory and 8 kB of RAM.
http://www.ti.com/lsds/ti/microcontroller/16-bit_msp430/2_series/overview.page
It is hard for me to imagine that an 8 bit AVR could even begin to compete with the 16 bit MSP430 for an ultra low power signal processing application.
