NEED EQUIPMENT SUGGESTIONS
I WOULD LIKE TO BUILD A MACHINE TO CONTROL OUR LOCAL LPFM RADIO STATION (KZOS) IN SAN MARCOS,TX. IT WOULD BE TETHERED TO AND CONTROLLED BY OUR MAIN COMPUTER. NEEDS TO CONTROL 3 SERVOS MOVING IN THE X,Y AND Z AXIS. IT WOULD EMULATE THE MOTIONS OF A CNC VERTICAL MILLING MACHINE. BASICALLY WITH CAMERA ATTACHED, IT WOULD BE ABLE TO SCAN THE VARIOUS EQUIPMENT CHECK SETTINGS AND PUSH BUTTONS TO ADJUST SETTINGS. ANY IDEAS?
IF NEEDED, I CAN SEND A DRAWING.
THANKS- DAVID
Servos are angular motors (less than 360 degrees rotation). You probably want stepper motors.
Or since there is apparently visual feedback, simple DC motors slowed-down with gears or pulleys might work.
The Arduino can control steppers (or servos) but stepper motors (or DC motors) need a driver circuit.
With a joystick or other simple controls/switches you can control DC motors without a microcontroller.
IF YOU USE AN AMPLIFIER, YOU WILL NOT NEED TO SHOUT.
