Give ideas how can i make more pleace for ground using nano.
i always used breadboard, but it takes a lot of pleace and most often i don't use anything except ground and 5v, so i need compact solution to minimize my projects.
Use smaller breadboard but with power rails.
Why is the size of a breadboard a problem? They are only for prototyping. Final projects would be soldered onto protoboard/stripboard/custom PCB in the size you require.
This is not an English word. I assume you meant space or places.
Use veroboard like below
Cut as may strips as you need. Solder your connections.
Your topic has been moved. Don't post in "Uncategorized"; see the sticky topics in Uncategorized - Arduino Forum.
I like these euro style terminal blocks
